RomanG
Servoblaster interfering with ALSA?
Sun Feb 03, 2013 4:34 pm
I have experienced strange issue.
After recent system upgrade to:
uname -a
Linux RPi 3.6.11+ #362 PREEMPT Tue Jan 22 14:52:21 GMT 2013 armv6l GNU/Linux
my audio (through an on-board audio jack) stopped working. There would be just static, even if nothing is playing, and when I would attempt to play a wav file through aplay or use espeak, there would be only high pitch pulsation (something between a fax machine signal and dolphin whistling).
I flashed back older backup image:
uname -a
Linux RPi 3.2.27+ #250 PREEMPT Thu Oct 18 19:03:02 BST 2012 armv6l GNU/Linux
and everything worked fine.
I searched forums and found some suggestions (i.e. uninstalling pulseaudio...etc) but nothing solved the problem.
Few days ago I was playing again with the servoblaster and had left one of the servos connected to the GPIO.
Today, when I run espeak the servo started to turn (continuous rotation modified servo).
Hmm...., that was weird.
So I unloaded servoblaster module and suddenly both, the aplay as well as espeak work fine.
As soon as I load servoblaster module back, I can hear the static in my earphones and when attempt to play a wav file or use espeak, I gett that high pitch pulsation again.
Unloading servoblaster module brings audio back.
Any suggestions highly appreciated!
thanks,
Roman
RomanG
Re: Servoblaster interfering with ALSA?
Mon Feb 04, 2013 4:52 pm
"Mystery" solved. Some explanation here:
http://www.raspberrypi.org/phpBB3/viewt ... 52#p277252
Roman
