You could download the packages needed with another computer, put them on external media such as a USB stick, and then install them from there. That is offline package installation, I have a page up about how to do that with pacman, although it may be slightly out of date, the basic technique is the same, I use that all the time for updating and adding packages to my Pi.
http://sdjf.esmartdesign.com/raspberrypi/pacman.html
You will also need to edit an appropriate profile in /etc/netctl, to suit your setup. copy an appropriate wireless profile from /etc/netctl/examples to /etc/netctl and edit it, removing the other one. You can install packages and update pi without having that profile working, but it will be necessary once the packages are installed, for them to run properly.
If you have not yet installed Arch at all, then the instructions are here and do not require any specific type of internet connection:
http://archlinuxarm.org/platforms/armv7 ... berry-pi-2
FORUM TIP: To view someone's posting history, sign in, click on their user name, then on "Search User's Posts." || Running ArchLinuxArm on Model 2B and 512MB Model B
