lilzz
how to implement software RAID
Thu Feb 12, 2015 12:50 am
Got corrupted sd card few times, how to implement a raid so it can self correcting therefore no need for me to 're image
mikronauts
Re: how to implement software RAID
Thu Feb 12, 2015 1:06 am
Raid only protects against storage failure, it does not inherently protect against storage being corrupted by improper shutdown.
lilzz wrote:Got corrupted sd card few times, how to implement a raid so it can self correcting therefore no need for me to 're image
lilzz
Thu Feb 12, 2015 1:38 am
mikronauts wrote:Raid only protects against storage failure, it does not inherently protect against storage being corrupted by improper shutdown.
I think it should work. Raid has a mirror section. If has trouble booting then it boot from mirror section.once booted ok, mirror section would urestore the main section. Like Windows recovery section.
stevech
Thu Feb 12, 2015 6:29 am
just remove the SD card and image copy your card every now and then using Windows or Linux. As a backup.
Thu Feb 12, 2015 4:10 pm
stevech wrote:just remove the SD card and image copy your card every now and then using Windows or Linux. As a backup.
No need to remove it. With a blank card in a USB reader you can clone while you run. With 1GB of RAM I can give that process 200 or 300MB and it's lightening fast (compared to running it on my storage constrained A+).
LaKraven
Thu Feb 12, 2015 4:23 pm
You should do a step-by-step tutorial on that one! It'd be a real crowd-pleaser :)
mikronauts
Thu Feb 12, 2015 4:40 pm
That depends on how much is in the write buffers, and if the raid software completes writes on one image before starting them on the other image.
Thu Feb 12, 2015 6:58 pm
There's lots of scripts and stuff (lots of forum posts) for how to do that. It's trivial.
