sorry for posting twice
I wasn't aware about controlling posts. On my netbook I've seen only the upper (empty) part of of that message and didn't scroll down.
Now I know it .
Rolf
Worked a treat. I didn't realise a camera could format a SD card by itself.Green12 wrote:@malc: Try to format the SD card in your camera,
In this case I don't think there's an issue with power, as I said the same hardware works perfectly with both Debian and RiscOS on the same Pi.Green12 wrote:@thekeywordgeek: Well, I had trouble with my Logitech K400 keyboard too. But it seems to be an issue by the powersupply. Wrong USB to microUSB - cable (was an HTC cable).
Trying another cable (Garmin) and it works (???!).
Maybe you should check your powersupply/ cable.
Greetings : Green12
Yes they are supposed to (and do) work with non-Windows computers. If 7-zip is really not opening it, I would suggest you download the .xz file again. (And you've written 'Z-zip' in two separate posts so I assume it isn't a typo and you either have a mental block over the name or you have found a decompression utility called thatmalc wrote:That error is with Z-zip.
These downloads arent only supposed to work on a Linux PC are they? As I'm trying to download them on my Main Windows 7 PC.
That should have been "Yes they are supposed to (and do) work with Windows computers." which has a completely different meaning!drgeoff wrote: Yes they are supposed to (and do) work with non-Windows computers.
