FourthLiner
Warning: Incompatible Operating System(s) Detected
Wed Feb 11, 2015 12:43 am
I am extremely new to using a Raspberry Pi. I have just received my first Raspberry Pi Model B+, and have followed the helpful instructional video about downloading and getting NOOBS to work.
So far I have downloaded and extracted the NOOBS files and moved them to a 16Gb micro SD card (the card has been formatted using the SD Card Association's formatter tool), and applied power to my Raspberry Pi with the SD card in the slot.
After clicking Raspbian as my OS of choice to install, I confirm that I want to install Raspbian, and then another confirmation window comes up that reads:
"Warning: incompatible Operating System(s) detected. The following OSes aren't supported on this revision of Raspberry Pi and may fail to boot or function correctly: Raspbian"
Yes/No
I am unsure if this confirmation window should be appearing or not and what my next step(s) should be.
I have read through some of the stickies on this page and I have not come across anything relating to this warning message.
If anyone could provide me some assistance it would be greatly appreciated.
Thanks.
antonbruhn
Re: Warning: Incompatible Operating System(s) Detected
Wed Feb 11, 2015 2:45 pm
Got the same problem when I'm trying to install raspbmc...
when i click yes it starts to install and it says that it was successful installations after a while, but then all turns black and the raspbmc won't boot. got the raspberry pi 2. Someone that can help me? Using a SanDisk 16gb microsd.
drgeoff
Wed Feb 11, 2015 3:22 pm
@antonbruhn
AIUI at the time of posting this, the NOOBS version of RaspBMC does not work on a RPi2. Nor does the image version of RaspBMC on the Downloads page at raspberrypi.org.
http://www.raspberrypi.org/forums/viewt ... 89#p691489
BMS Doug
Wed Feb 11, 2015 3:26 pm
antonbruhn wrote:Got the same problem when I'm trying to install raspbmc...
RaspBMC isn't compatible with the pi2 and never will be, the developer of RaspBMC has moved his efforts to developing OSMC instead. The Developer of RaspBMC and OSMC claims that OSMC is compatible with the Pi2 (I have no reason to doubt that).
You can get the latest version of OpenElec from their website but not through NOOBS (I don't think the version that you would get through NOOBS has been updated to the latest one yet).
Doug.
B.Goode
Wed Feb 11, 2015 3:46 pm
That doesn't help the original enquirer @FourthLiner who is attempting to install Raspbian...
I recall a similar issue when the Model A+ was released, but this is about a B+: which version of NOOBS have you downloaded and installed please?
FourthLiner
Wed Feb 11, 2015 11:58 pm
I have downloaded the current version available under the downloads section:
NOOBS version 1.3.12, release date 2015-02-02.
Since posting this originally, I have clicked "YES" to confirm and gone ahead with the installation of Raspbian.
Everything seems to be working correctly, I am not sure if I should be expecting any possible problems with the Raspberry Pi not working properly.
Papabravo
Tue May 26, 2015 4:42 pm
Using NOOBS 1.4.1 works fine on RPi 2, but gives the warning: that Raspbian is not supported on the B+
I ignored the warning and continued. The process completed anf said the OS was installed correctly. I'll post again if I run into problems.
cspencerjr
Wed Jul 01, 2015 2:05 am
New to Raspberry Pi, and I got the B+ 512MB version.
I just downloaded the latest NOOBS and got the same error:
Is this a bug in NOOBS? Should I ignore it for now?
Wed Jul 01, 2015 7:51 am
It's a bug in NOOBS. Ignore it.
