braitac
PI 2 heatsinks
Tue Feb 10, 2015 3:09 pm
I have just received my new PI 2 B and my heatsinks. (upgrade from PI 1 B)
No problem to install the two bigger heatsink.
For the little third one I have no idea where I should place it.
What is the location for the third heatsink on the PI 2 B ?
Re: PI 2 heatsinks
Tue Feb 10, 2015 3:15 pm
Dunno, I've never used any heatsinks. Find a chip that feels hot and try that one.
(You don't really need heatsinks)
BMS Doug
Re: PI 2 heatsinks
Tue Feb 10, 2015 3:19 pm
I've got a heatsink and cooling fan for My Pi, I keep meaning to post photos.
Doug.
Building Management Systems Engineer.
braitac
Re: PI 2 heatsinks
Tue Feb 10, 2015 3:23 pm
It shouldn't be required under normal conditions but my PI will be near a high source of heat. :?
Also I already have them from the PI 1 so let's reuse them.
Also the PI 1 was quite hot so it cannot do harm to put them ! :roll:
Yes if you have the B+ or 2B 's photos I would indeed appreciate, thanks ;)
braitac
Re: PI 2 heatsinks
Tue Feb 10, 2015 3:26 pm
I found this picture but nowhere can I found the third one .....
Learntofly
Re: PI 2 heatsinks
Tue Feb 10, 2015 3:43 pm
Without getting Into the merits or non merits of heatsinks, I think the idea of the 3 pack of heatsinks was for the original model B, one on the SOC, one on the LAN controller and one on RG2 the 3.3v voltage regulator (the three red spots on this image) Image
However the RPI B+ and 2 now use a switching mode regulator which would not get hot anyway..
Regards
braitac wrote:I found this picture but nowhere can I found the third one .....
braitac
Re: PI 2 heatsinks
Tue Feb 10, 2015 3:49 pm
Learntofly wrote:Without getting Into the merits or non merits of heatsinks, I think the idea of the 3 pack of heatsinks was for the original model B, one on the SOC, one on the LAN controller and one on RG2 the 3.3v voltage regulator (the three red spots on this image) Image
Regards
Thanks then this is the answer. No need for the third one :P
I ll just "feel" as jamesh suggested anyway.
Too bad someone couldn't provide a heat map for the new PI 2 it would have been cool.
In the meantime I can only help with this :D
http://www.amazon.com/Etekcity-Lasergri ... e+infrared
BMS Doug
Re: PI 2 heatsinks
Tue Feb 10, 2015 4:21 pm
braitac wrote: Too bad someone couldn't provide a heat map for the new PI 2 it would have been cool.
I'll bring my Pi2B to work tomorrow and take a heat picture with our thermal imager.
Doug.
Re: PI 2 heatsinks
Tue Feb 10, 2015 5:23 pm
braitac wrote:It shouldn't be required under normal conditions but my PI will be near a high source of heat. :?
Make sure, if near a high source of heat, that the heatsink isn't working in reverse....
rpdom
Re: PI 2 heatsinks
Tue Feb 10, 2015 5:49 pm
Stick it on the RAM chip on the other side of the board.
Re: PI 2 heatsinks
Tue Feb 10, 2015 7:50 pm
rpdom wrote:Stick it on the RAM chip on the other side of the board.
I can think of better places to stick it but can't tell you on a family forum.
asandford
Re: PI 2 heatsinks
Tue Feb 10, 2015 11:46 pm
From here
Although while idling the new Pi will not consume any more power than the previous generation of boards, when all four cores are being used the new board will consume more power and — due to increased leakage — will get much hotter. Hot enough that you might want to think about adding a heat sink, especially if you intend to overclock the chip.
BMS Doug
Re: PI 2 heatsinks
Wed Feb 11, 2015 9:49 am
Pi2B Thermal Image
The Pi was setup to launch straight into X, but as I don't have a HDMI monitor at work I couldn't really load it up.
Doug.
braitac
Re: PI 2 heatsinks
Sat Feb 14, 2015 11:58 pm
Thanks for the replies !
I also found this video about the thermal image of the RPI2 B
https://www.youtube.com/watch?v=Mhio0dE4Dzk
LUCYII
Re: PI 2 heatsinks
Wed Mar 09, 2016 11:33 am
I use the raspberry pi2 with openelec media software and the temperature goes up to 50°C after a few hours.
I insert 2 heatsinks and a fan, then the temperature goes down and is now between 33°C and 42°C.
I think that i place on the new PI3 board also the heatsinks and a fan.
Return to “Beginners”
