ok so i was following https://bitbucket.org/inkubux/cubox-i/w ... x%20Wheezy to get plex media server up and running,
i got as far as
quote " You should have access to your plex server at the following address
http://<<Your IP Address>>:32400/web/index.html "
and sure enough the server was up and running
I decided i would mount a folder from my external drive to the library folder so that the meta data didnt take from what little space i have on the sd card but first i needed to shutdown plex.... since the pi is not windows there is no task manager so figured best bet was to tell the pi to restart
only when it booted up it gets as far as mounting my hard drive and then just stops, the cursor is blinking, i can type but its not continuing the boot
any ideas? i really dont want to reset it all back to square one, been working on getting it setup for a fair few hours now
im sure its an issue with the fstab file, its mounting my hd but imguessing since the chroot program is not running it cant mount the folders beyond that
