I have a pi b+ powered by 1A wall switching adapter and I connect the A/V output of the PI (just Right , Left and Ground ) to an external amplifier (3W) which shares the same power supply (5Volt)
If I dont play anything via omxplayer command , I hear a lot of noises in my 4ohm speaker. If I surf on apache http web server of my PI from a PC browser , the noise incrases. It seems everithing I do in the pi is replicated in my speakers.
So I decided to switch off the amplifier and to connect the A/V output to the microphone input of the PC (the PC doesnt share the same ground since its powered from its battery) but the noise is still there .
The only way I can get all working is using 1 switching power source for the amplifier and one for the pi and connecting them with the audio cable.
I started to think about ground loop, ferrite baeds, EMI issues and so on but I still cant find the reason of this noise.
I wonder if anybody was able to power the pi and an external class D amplifier using the same power supply or mybe I'm losing some important aspects to consider.
Hope you can support .
Thanks in advance
Nico
