Si3Ste
[Solved] Deactivate Cores
Mon Feb 09, 2015 4:02 pm
Hi all,
I own some Raspberry 2 since last end of Week and I believe that 4 cores are too much for me :)
Is there is way to deactivate/park some of the cores ( for me 2 is enough ) ? It will reduce power consumption and heat.
Regards
Si3Ste
jdb
Re: Deactivate Cores
Mon Feb 09, 2015 4:39 pm
Edit /boot/cmdline.txt and add maxcpus=N
Where N is in range 1 to 4.
Rockets are loud.
https://astro-pi.org
Mon Feb 09, 2015 4:40 pm
I would be interested to know how much that reduces current draw. I suspect not a lot, but waiting for someone to work out the figures!
pluggy
Mon Feb 09, 2015 4:47 pm
http://raspi.tv/2015/raspberry-pi2-powe ... easurement
This suggests 40mA per fully loaded core, But getting it to fully use all the cores is tricky. Disabling 2 of the cores would make little or no difference in the real world I reckon.
Si3Ste
Fri Feb 13, 2015 2:14 pm
Well, tried, it works but don't seems to change manything. not even 2-3 degree less on my tests
jdb
Fri Feb 13, 2015 3:39 pm
The cores are being clock-gated when not in use (either not being used by Linux, or no active tasks running), therefore you will still have static leakage dissipation. Essentially the maxcpus=N directive limits the maximum power consumption by proxy, with negligible effect on idle power consumption.
Rockets are loud.
mkirk
Re: [Solved] Deactivate Cores
Tue Aug 20, 2019 9:25 pm
Questions:
1) For maxcpus=4, if one CPU core is at 100% load and running at max clock, e.g. 1.2 GHz.
Are the other 3 cores (idle) also clocked at 1.2GHz? Or do these idle cores run at min clock , e.g. 600 MHz?
2) Does an idle core running at max clock use same power as a core with 100% load?
I am guessing yes, since my testing with stress and sysbench for 2 cores gives similar results (temperatures) as 1 and 4 cores.
jdb
Wed Aug 21, 2019 4:02 pm
Try replacing maxcpus=n with isolcpus=n. All CPUs get the same clock, but temperature under load should definitely reduce with <4 CPUs online.
Rockets are loud.
Return to “Advanced users”
