PeterO
Why is the PI2 camera-shy ?
Sat Feb 07, 2015 1:53 pm
I have discovered that my PI2 is camera-shy !
Taking it's picture with a flash causes an instant power off !
I've done it three times now and same thing happens each time.
First two times I didn't realise what had happened as I wasn't looking at the screen at the time and only noticed a few minutes afterwards.
Third time I did it just to watch the screen.... Instant power off.....
Any ideas ?
PeterO
Interests: C,Python,PIC,Electronics,Ham Radio (G0DZB),Aeromodelling,1960s British Computers.
pluggy
Re: Why is the PI2 camera-shy ?
Sat Feb 07, 2015 1:59 pm
An entirely separate camera or on that is powered through the Pi ?
If its a separate camera, thats spooky.
rurwin
Sat Feb 07, 2015 2:04 pm
EMP from the capacitor discharge inducing a spike in the power cable?
Seems unlikely.
A lot of semiconductors are light-sensitive. Maybe the reverse-polarity diode on the power input? It would need to get through the opaque case but the casing of small surface-mount components can't be too thick.
Seems almost as unlikely though.
Edit: I was expecting batteries, but if it's connected to power, then it's a voltage spike. A sharp spike can get through anything; down the power line to mains and back up into the RaspPi is not unlikely. Even more so if it's connected closer of course.
PeterO
Sat Feb 07, 2015 2:12 pm
No electrical connection between camera (battery powered) and the PI. I would suspect it is an "photonic" effect of some sort on a poorly encased semiconductor. Something in the power circuits does sound likely.
PeterO
ktb
Sat Feb 07, 2015 2:21 pm
Neat trick. What model camera is it?
PeterO
Sat Feb 07, 2015 2:22 pm
ktb wrote:Neat trick. What model camera is it?
I doubt that is important !
PeterO
ktb
Sat Feb 07, 2015 2:27 pm
[quote="PeterO"][quote="ktb"]Neat trick. What model camera is it?[/quote]
PeterO[/quote]
Fair enough. I was slightly interested in attempting to reproduce the problem and was wondering if my Canon 500D or Moto X would do the trick.
pluggy
Sat Feb 07, 2015 2:43 pm
You could always try attenuating the flash with a thoughtfully placed finger to reduce its impact. Something I do when taking close ups to stop it washing out the picture.
Burngate
Sat Feb 07, 2015 6:58 pm
Power-off or just crash? What are the symptoms?
I'm probably teaching grandma to suck eggs but ...
How far away does the camera have to be to not affect the Pi?
Does it still do it in the next room? With the door closed?
How about with the Pi at the other end of the garden, but with the flash pointing at it?
How about powering it from batteries, disconnecting the monitor etc. then setting off the flash. Then plug the monitor and keyboard back in to see what happened.
jdb
Sat Feb 07, 2015 7:03 pm
Do you have any blu-tac?
Rockets are loud.
https://astro-pi.org
PeterO
Sat Feb 07, 2015 7:06 pm
Burngate wrote:Power-off or just crash? What are the symptoms?
To all intents and purposes it was OFF. Red light still showing, but no other signs of life. The screen went into standby so no video output.
I suggest you get your own PI2 if you want to know the answers to all those questions.... :roll:
PeterO
PeterO
Sat Feb 07, 2015 7:11 pm
jdb wrote:Do you have any blu-tac?
I do, but I don't have the need for any more pictures of it :-) I don't want to keep "upsetting" it as I'm actually developing code on it right now !
PeterO
jdb
Sat Feb 07, 2015 7:12 pm
Ok - I've managed to reproduce the problem here, anyway.
Rockets are loud.
Sat Feb 07, 2015 7:17 pm
jdb wrote:Ok - I've managed to reproduce the problem here, anyway.
Is this an experiment we can all do? Or does it need some quaint camera/flashgun hardware?
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
Since 2012: 1B*5, 2B*2, B+, A+, Zero*2, 3B*3
Please post ALL technical questions on the forum. Do not send private messages.
mikerr
Sat Feb 07, 2015 7:27 pm
Confirmed here too.
Took photo with flash using Samsung Note2 - Pi 2 remains ok
Took photo with Samsung K Zoom - Pi 2 crashes.
Oh, and its a freeze, not a crash-reboot at that point.
(display blanks, SSH and mouse/keyboard inoperative until power cycled)
Note the K Zoom has a Xenon flash, unlike most cameraphone's LED flash.
jdb
Sat Feb 07, 2015 7:34 pm
Xenon flashes cause the issue.
I have a 1800 lumen LED bicycle headlight - on flash mode at ~3cm distance from the Pi, it doesn't cause a crash.
With a Canon Ixus 60 (handheld compact camera), its flash reliably locks up the Pi. You need to be closer than about 50cm to make it happen, though.
Rockets are loud.
toxibunny
Sat Feb 07, 2015 7:51 pm
fascinating.
note: I may or may not know what I'm talking about...
PiGraham
Sat Feb 07, 2015 8:13 pm
What if you cover the Flash with card?
Is it the light or em pulse?
gregeric
Sat Feb 07, 2015 8:16 pm
I recall way back easing the metal lid off the 2114 ram chips (1024 x 4 bit, 2 needed per KiB) on my Ohio Scientific Superboard 2 to peer inside to wonder at the ordered layout beneath. A desk lamp with tungsten filament bulb held above was enough to trigger errors. +30 years, now we need xenon flash.
jdb
Sat Feb 07, 2015 8:32 pm
PiGraham wrote:What if you cover the Flash with card?
It's light-triggered.
Rockets are loud.
mikerr
Sat Feb 07, 2015 8:50 pm
Tried my other Pi
A/B/A+/B+ are all immune from the "XENON DEATH FLASH" :mrgreen:
Going back to the Pi 2, I thought it might be the SoC (now it has no RAM on top - the ram is underneath on the Pi 2)
- bluetack over the SoC wasn't enough to save it crashing, nor was a few sheets of A4,
turning it upside down saved it though !
Sat Feb 07, 2015 9:00 pm
mikerr wrote:Going back to the Pi 2, I thought it might be the SoC (now it has no RAM on top - the ram is underneath on the Pi 2)
So, not the SoC then. It must be something else on that side of the board. Should be simple to track down by masking off regions.
If it had been the SoC, this could have been an actual situation where a heatsink might have served a useful purpose...
jdb
Because the blu-tac blob isn't over the single photosensitive IC on the board.
It appears that U16, the SMPS chip, is the culprit.
Rockets are loud.
PeterO
Sat Feb 07, 2015 9:09 pm
jdb wrote:Because the blu-tac blob isn't over the single photosensitive IC on the board.
Where is that so we can see if covering stops the XENON DEATH FLASH :evil:
PeterO
mikerr
Sat Feb 07, 2015 9:14 pm
Yes, bit of bluetac on that chip and it survives the flash:
Looking at the board under strong light, both U8 and U16 are much more reflective than other chips,
but as you say covering U16 fixes the issue.
Who is online
Users browsing this forum: FTrevorGowen and 37 guests
