Methanoid
Re: Ubuntu / Linaro for Raspberry Pi 2
Fri Feb 20, 2015 3:17 pm
Mequa wrote:Is this even permitted?
wget http://archive.raspberrypi.org/debian/pool/main/p/pistore/pistore_1.1.16693_armhf.deb
sudo dpkg -i pistore_1.1.16693_armhf.deb
sudo apt-get -f install
pistore
It works. I've just been playing Cookie Clicker on Ubuntu Linaro, from the Pi Store...
Did NOT work as shown....... Is there something missing like installing the dependencies?
[email protected]:~$ sudo dpkg -i pistore_1.1.16693_armhf.deb
Selecting previously unselected package pistore.
(Reading database ... 42973 files and directories currently installed.)
Preparing to unpack pistore_1.1.16693_armhf.deb ...
Adding group `indiecity' (GID 1002) ...
Done.
chgrp: cannot access ‘/var/lib/indiecity/*’: No such file or directory
chgrp: cannot access ‘/usr/local/bin/indiecity/*’: No such file or directory
find: `./InstalledApps/*/Full/*_reg.xml': No such file or directory
Unpacking pistore (1.1.16693) ...
dpkg: dependency problems prevent configuration of pistore:
pistore depends on libqtwebkit4; however:
Package libqtwebkit4 is not installed.
dpkg: error processing package pistore (--install):
dependency problems - leaving unconfigured
pistore
Mequa
Sat Feb 21, 2015 3:46 am
pistore
Done.
pistore
I got the above error and then did "sudo apt-get -f install" (as stated) and it correctly fixed this problem and installed the dependency "libqtwebkit4" from the Ubuntu repositories.
Then Pi Store starts successfully from either the Terminal or the menu, at least in my experience.
This may possibly break the Ubuntu Software Center ("sudo apt-get install software-center"), more testing and workarounds may be needed. Also, not all Pi Store apps will install and/or run on Ubuntu Linaro. Cookie Clicker is one example which does work.
(I don't currently have this to test on an SD card right now, I'm re-using my second 32GB micro-SD for video at present.)
mikethebos
Sun Feb 22, 2015 12:55 am
How do I get the MATE desktop environment running on this image?
Mike
nhjeffh
Realtek-based Wireless adapter
Mon Feb 23, 2015 12:56 am
Hs anyone successfully gotten the Realtek (wireless) 8188CUS adapter to work with this distribution?
Mequa
Mon Feb 23, 2015 7:34 pm
The following seems to work, and installs the Pi Store on Ubuntu Linaro without giving any error messages:
sudo apt-get -f install libqtwebkit4
pistore
Unfortunately this does seem to break the Ubuntu Software Center for some reason.
tomhk
Re: Realtek-based Wireless adapter
Wed Feb 25, 2015 2:51 am
nhjeffh wrote:Hs anyone successfully gotten the Realtek (wireless) 8188CUS adapter to work with this distribution?
I got it working by remove the wps_gui and install wicd-curses
That's what I did, a bit of trial and error so the steps are not 100% correct, let me know if you have any problem with it.
Install python-urwid
https://launchpad.net/ubuntu/vivid/armh ... id/1.2.1-2
Install wicd-daemon
https://launchpad.net/ubuntu/vivid/armh ... 4.1ubuntu1
Install wicd-curses
Use 'sudo dpkg -i xxxx.deb' to install, xxxx.deb is the file you downloaded from the above links.
You may need to use 'sudo apt-get -f install' to fix the dependency issues if you one.
wintrmute
Wed Feb 25, 2015 6:35 am
tomhk wrote: I got it working by remove the wps_gui and install wicd-curses
Why didn't you just do "apt-get install wicd-curses" ? That should download and install it plus the dependencies automatically.
mikethebos
Wed Feb 25, 2015 4:35 pm
How do I setup automatic wireless joining at boot? How do I start a VNC server at boot after the wireless connects? And SSH?
Frays
Wed Feb 25, 2015 4:44 pm
Awesome ! Thank you very much !
Does anyone know how to disable screen blanking after some minutes and how to auto login ?
wintrmute
Thu Feb 26, 2015 12:26 am
mikethebos wrote:How do I setup automatic wireless joining at boot? How do I start a VNC server at boot after the wireless connects? And SSH?
These sort of questions will have answers in regular Ubuntu forums, if you look there. They're not Raspberry-specific. Might save you some time is all :)
Although the automatic wireless connection is answered in this very thread - search for "wpa-psk".
I don't know if you noticed, but an ssh server is already setup in this image.
mikethebos
Thu Feb 26, 2015 12:46 am
I do not see specifics on how to make wireless auto join at boot. Is it the networkinterfaces file?
Thu Feb 26, 2015 1:17 am
It's in the interfaces file or wpa_supplicant.conf depending how you've defined the SSID and psk.
This is a doctor free zone.
iinnovations
Sat Feb 28, 2015 12:01 am
I noticed that this distro had no /etc/wpa_supplicant/wpa_supplicant.conf file. Had to create one, but other than that worked fine with wpa and 8188. I'm not sure why others were having problems.
LogMeIn Hamachi took a slight workaround:
http://www.cupidcontrols.com/2015/02/ru ... tu-linaro/
C
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
Signa1
Sat Feb 28, 2015 8:27 pm
Anyone know if screen rotation (portrait mode) is possible?
mikethebos
Sat Feb 28, 2015 9:52 pm
If people are having issues with the authentication agent, run:
sudo apt-get install systemd-sysv
and reboot
mikethebos
Sat Feb 28, 2015 9:55 pm
Has anyone gotten Minecraft Pi working on this distro yet?
gewin
Sun Mar 01, 2015 5:59 am
mikethebos wrote:If people are having issues with the authentication agent, run:
and reboot
Is this related to the " Failed to start unit [email protected]: Unknown unit " I get when trying to boot. I get this randomly and haven't worked out how to fix it. Except reflash sd card from backup. Not sure if it is related to unclean shutdown or something I have changed. I notice their is an open bug for 14.10 regarding this type of error but not sure it is related.
sshanky
Sun Mar 01, 2015 6:46 am
Can anyone point me in the right direction to find out how to change the display resolution and rotation? I learned how to change a config file in Raspbian that would allow portrait orientation with a specific resolution, but I do not know how it works on this.
Thanks a lot!
mikethebos
Sun Mar 01, 2015 4:23 pm
and reboot
As seen on https://bugs.launchpad.net/ubuntu/+sour ... ug/1359439 it's related. Run that command and reboot. Don't worry about packages like ubuntu-minimal getting removed, they aren't needed! Let us know if it works out!
mitchelln
Mon Mar 02, 2015 9:05 am
Hi.
I've just installed this on my PI 2. What a difference! I run a mediawiki instance on the board and with the latest Rasbian it was taking around 10 seconds to render a page and I was a bit disheartenend. I then tried this Linaro build and now the pages render in around 2 seconds. An amazing improvement. It's really usable now. Great job and thanks for the effort!
I do have a question. I have a RasClock V3.0. Has anyone got this working? There is a prebuilt module, but it's for a different kernel version. I assume I'm going to have to build the module?
Thanks.
gewin
Mon Mar 02, 2015 9:11 am
and reboot
This partially solves my problem, after the sudo apt-get install systemd-sysv and rebooting. The error messages (as above) went away and I was presented with a login prompt (in cmdline mode). I logged in with username and password so I am now at cmdline $. I don't seem to be able to start the graphics environment. sudo startx - no command, sudo start gdm - failed to connect to socket /com/ubuntu/upstart: connection refused, sudo /etc/init.d/lxdm start - nothing happens. Forgive my ignorance, how do I restart the standard desktop. My previous configurations was to autologin to an account and start the desktop. Now I just have a cmdline interface.
eriktheitalian
Mon Mar 02, 2015 9:42 am
Note for atheros based wifi / bluetooth users:
Default ubuntu 14.10 not support atheros based wifi / bluetooth.
I cant using enough English language. My writings can be wrong grammer.$
"in micro$oft we not trust"
Mon Mar 02, 2015 10:34 am
mitchelln wrote:Hi.
Thanks.
Interesting, I wouldn't expect this to be 5 times faster than Raspbian on the same machine. Anyone know where the improvements are?
Methanoid
Mon Mar 02, 2015 10:39 am
You have to wonder why this isn't made available via the official downloads and on NOOBS. Why would anyone want to use Raspbian on a Pi2 now? Am I missing something?
gkreidl
Mon Mar 02, 2015 10:58 am
Methanoid wrote:You have to wonder why this isn't made available via the official downloads and on NOOBS. Why would anyone want to use Raspbian on a Pi2 now? Am I missing something?
Yes, you are missing almost everything.
1) For the foundation compatibility between all sold RPis is very important. And splitting up the community (support!) doesn't look like a good idea to me.
2) I don't think there's anything on Ubuntu that you cannot do with Raspbian (both are based on Debian). At the moment Ubuntu will provide newer packages than Raspbian but that will soon change when we migrate to Jessie.
3) Do you have a working HW accelerated media player on Ubuntu now? Last thing I heard was that omxplayer couldn't be installed.
4) There's some stuff that is only available for Raspbian (because of special deals), as Wolfram/Mathematica, Oracle Java etc.
5) What may be speaking for Ubuntu is the native ARMv7 code, but the Foundation is working on a solution that will add ARMv7 packages without breaking compatibility completely.
BTW, I'm a long time user of Ubuntu on my desktop computers. But I won't migrate to it on my RPis.
Minimal Kiosk Browser (kweb)
Return to “Other”
