blavery
Re: Webiopi doesn't work on Raspberry Pi 2
Tue Feb 23, 2016 10:44 am
It is my opinion that persevering with a utility that has had no support since the time of RPI2 introduction a year ago, is asking for frustration. Everything else has moved on.
danjperron
Tue Feb 23, 2016 12:10 pm
Error 500 is a general error!
Do you have a Raspberry Pi2 ?
Did you install the patch for the Pi2?
Mettauk
Wed Mar 02, 2016 12:03 am
Seems to patched version does not work on the Pi3 b either!
As humans we have been the same for a very very long time, technology changes how we do... not who we are as people.
studium
Fri Mar 11, 2016 9:42 pm
The same error, is there solution?
I have installed WebIOPi as root user.
http://host:8000/
HTTP/1.0 500 Internal Server Error Server: WebIOPi/0.7.1/Python3.5 Date: Fri, 11 Mar 2016 21:31:51 GMT Content-Type: text/html;charset=utf-8 Connection: close Content-Length: 458
Error response
Error code: 500
Message: Internal Server Error.
Error code explanation: 500 - Server got itself in trouble.
studium
Fri Mar 11, 2016 9:45 pm
My patch was https://github.com/doublebind/raspi
Unfortunately, it is not work.
I got: HTTP/1.0 500 Internal Server Error Server: WebIOPi/0.7.1/Python3.5 Date: Fri, 11 Mar 2016 21:31:51 GMT Content-Type: text/html;charset=utf-8 Connection: close Content-Length: 458
danjperron wrote:Error 500 is a general error!
Mettauk
Sat Mar 12, 2016 9:46 pm
I have the patched version now working with a Pi 3b so it is possible!! But, it does give errors on instalation so it might not be "fully" working?!
cottoncandyek
Fri Mar 18, 2016 5:40 pm
Mettauk wrote:I have the patched version now working with a Pi 3b so it is possible!! But, it does give errors on instalation so it might not be "fully" working?!
I tried to PM you but I don't think I can yet since I'm new. Anyway you could share how you got it to work? struggled with it last night and couldn't resolve it. Any help would be much appreciated
cmartu
Sat Mar 19, 2016 2:14 am
Followed the procedure posted by danjperron and WebIOPi WORKS ! for me now :)
Thank you!
Overdose
Thu Mar 24, 2016 10:46 am
Thank you danjperron :) The patches worked well for me ;)
MikeGreany
Thu Jan 26, 2017 4:03 am
Ok not to beat a dead horse that has been dead almost a year now, but I cannot get Webiopi to work no matter what I do. I have a model 2B running Jessie and I have done a ton of research and tried various things. I have no programming experience however I can google search like the best of them. I have edited the cpuinfo.c file myself, as well as the gpio.c file, I ran everything in danjperron's post for the patches and still not working. When I navigate to the IP all I get no matter what changes I do is what you see in the screen shot, and that is using various browser (Chrome, Chromium, Firefox). Any help is appreciated because I am out of ideas. I am not all that technical but I like to look this stuff up and learn.
ek792
Mon Feb 20, 2017 5:13 am
konglingboy wrote:1.python/native/cpuinfo.c,change "BCM2708" to "BCM2709";
2.python/native/gpio.c, change "#define BCM2708_PERI_BASE 0x20000000" to "#define BCM2708_PERI_BASE 0x3f000000";
3.run setup.sh again.
Thanks a lot. This worked a treat for me.
lestra
Tue Feb 28, 2017 7:01 pm
This problem persist on raspberry pi 3 as well.
I fix this problem with:
sudo apt-get update
sudo apt-get upgrade
reboot raspberry
then start again service webiopi ;)
Re4per
Mon Mar 20, 2017 6:43 pm
Hello together,
it seems that there is still at least one issue with the doublebind patch.
I've installed 2016-05-27-raspbian-jessie-lite on my Pi 2 and got the same Error as MikeGreany stated before. The wierd thing is, some time ago i had a hard one doing it on the same hardware and i remember that i did the patching "manual" to the files and some other things. In the end i did several things and got it to work.
The poor thing is, that i've draw it from a forum were the patch was discussed, and there was an issue with my Board Rev not to be reflected inside the patch and how to fix this. But this threat is gone, can't find it furthermore on the net, maybe due to moving code to goolge ?! I don't know.
My board Rev is:
Hardware        : BCM2709
Revision        : a01041
Serial          : 00000000797ac02f
I've checked it this time, and i find it should be working, but it doesn't.
While installing the patched webiopi, i found those errors which indeed cause the problems.
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c native/gpio.c -o build/temp.linux-armv7l-2.7/native/gpio.o
native/gpio.c: In function âsetupâ:
native/gpio.c:90:5: warning: implicit declaration of function ânumber_of_coresâ [-Wimplicit-function-declaration]
     if (get_rpi_revision() <= 2  || number_of_cores() <= 2)
arm-linux-gnueabihf-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -Wstrict-prototypes -fno-strict-aliasing -D_FORTIFY_SOURCE=2 -g -fstack-protector-strong -Wformat -Werror=format-security -fPIC -I/usr/include/python2.7 -c native/cpuinfo.c -o build/temp.linux-armv7l-2.7/native/cpuinfo.o
native/cpuinfo.c: In function âget_cpuinfo_revisionâ:
native/cpuinfo.c:38:7: warning: ignoring return value of âfgetsâ, declared with attribute warn_unused_result [-Wunused-result]
       fgets(buffer, sizeof(buffer) , fp);
but this isn't saying a bit to me.
Am i obviously missing something so far ? Any ideas or comments would be very appreciated. Never the less i will continue trying to find the problem.
Thank you very much
Re4per
Sat Mar 25, 2017 7:56 pm
Hi all,
just to finish things, i've found it. I had to
sudo apt-get install rpi.gpio
and reinstall the patched webiopi. It still gives me the two shown errors, but as far as i tested it, everything works. :D
:arrow: Caveadd, python3 will also be installed with it.
Also tried to fix this by doing
sudo apt-get update
sudo apt-get upgrade -y
on a fresh install, but this did not work for some reason.
Maybe this helps others aswell
Cheers
