GiorgioFoX
BadMatch on PI2
Wed Feb 04, 2015 10:08 pm
I've followed this tutorial: http://www.rs-online.com/designspark/el ... nu-radio-2 to install GNU-RADIO COMPANION and some tools.
Every program that I try to use, for example just OSMOCOM_FFT give the error:
BadMatch (invalid parameter attributes) serial 1732 Error_code 8 request_code 70 minor_code 0
Also gnuradio-companion, or GQRX.
What can I do?
thanks
Giorgio
VinieBerry
Re: BadMatch on PI2
Thu Feb 05, 2015 8:44 pm
I followed the same tutorial and I can run osmocom_fft without connecting yet any RF tuner. I will confirm that as soon as I installed the toolchain for the bladeRF.
GiorgioFoX
Re: BadMatch on PI2
Thu Feb 05, 2015 10:15 pm
It's strange!
You have download this?
Debian Wheezy
Version:January 2015
Release date:2015-01-31
Or the NOOBS 1.3.12?
I've tried both. Followed the tutorial, startx, open terminal and osmocom_fft give me the error.
Now I try on a new uSD, and I will try also to install bladeRF toolchain (can you please give me a link?)
thanks
Giorgio
GiorgioFoX
Re: BadMatch on PI2
Thu Feb 05, 2015 10:58 pm
I've just tried again:
Booted from a new microSD card, with another Raspberry PI 2 (I have two units here), and this is my steps:
sudo nano  /etc/apt/sources.list
added deb http://archive.raspbian.org/raspbian jessie main
sudo apt-get update
sudo apt-get install gnuradio gnuradio-dev
sudo apt-get install rtl-sdr gr-osmosdr
sudo reboot
then
startx -> open terminal -> osmocom_fft
and this is my error:
https://www.dropbox.com/s/gtvk1d8llv7x2 ... 9.jpg?dl=0
What I'm doing wrong?
I've tried with RTLs, HackRF and FCD+
thanks
Giorgio
GiorgioFoX
Re: BadMatch on PI2
Thu Feb 05, 2015 11:36 pm
Solved!
sudo nano /boot/config.txt
and add
framebuffer_depth=32
framebuffer_ignore_alpha=1
VinieBerry
Re: BadMatch on PI2
Fri Feb 06, 2015 6:44 am
Good :D
g0ukb
Re: BadMatch on PI2
Fri Feb 13, 2015 11:01 am
Giorgio - Thank You!! I was have a BadMatch error too and your fix fixed it for me.
it9ybg
Re: BadMatch on PI2
Mon Jun 01, 2015 8:28 pm
I followed your guide, but I finally I have this error ... please help
pi@raspberrypi ~ $ osmocom_fft
linux; GNU C++ version 4.9.1; Boost_105500; UHD_003.007.003-0-unknown
  File "/usr/bin/osmocom_fft", line 35, in <module>
    from gnuradio import blocks
  File "/usr/lib/python2.7/dist-packages/gnuradio/blocks/__init__.py", line 34, in <module>
    from stream_to_vector_decimator import *
  File "/usr/lib/python2.7/dist-packages/gnuradio/blocks/stream_to_vector_decimator.py", line 23, in <module>
    from gnuradio import gr
  File "/usr/lib/python2.7/dist-packages/gnuradio/gr/__init__.py", line 53, in <module>
    log.add_console_appender(prefs().get_string("LOG", "log_level", "off"), 'gr::log %d :%p: %m%n')
  File "/usr/lib/python2.7/dist-packages/gnuradio/gr/runtime_swig.py", line 3963, in singleton
    return _runtime_swig.prefs_singleton()
RuntimeError: locale::facet::_S_create_c_locale name not valid
'73 de Pepè (call:IT9YBG) :)
My blog: https://it9ybg.blogspot.com/
sac78008
Re: BadMatch on PI2
Fri Jul 10, 2015 6:25 pm
@ ity9bg
I started out with your error (that's how I got to this page). After consulting der Google I found this workaround:
http://tech.enekochan.com/en/category/g ... x/page/15/
The error was solved by using this command:
export LC_ALL=C
But now I'm getting the "BadMatch" error and the config.txt edit didn't seem to fix it.
Anybody else get to stuck here? Help appreciated!
RP2bam
Re: BadMatch on PI2
Thu Apr 21, 2016 12:33 am
:P Thanx Giorgio I had the same problem with 2016-03-18-raspbian-jessie and osmocom_fft
Return to “Raspberry Pi OS”
