Hi All,
Have 40 years of Electronics construction, troubleshooting and repair. Have even built a working saltwater fishtank controller that the PI controls with some surface mount components, so I'm no stranger to PCB's. I built my TNC-Pi last weekend, and have it set up on my Model B. It's hooked to a Baofeng UV-B5. I can xmit fine, and the HT is picking up a good bit of APRS traffic. DCED LED is coming on good with each received signal. However, regardless of whether I set it up as i2c or serial, xastir doesn't show anything, and not even in the TNC data logs. I have also used axlisten, and I get absolutely nothing there as well. Have gone over the board multiple times with a magnifying glass looking for any cold solder joints, bridges etc and everything looks good. Even re-flowed every joint on the board just in case. Checked every IC to make sure I had no bent pins etc...
Any suggestions?
