change p6 to whatever partition you have mounted as the rootfs
there's p1 and p2. how do I know which one is mounted as the rootfs? I guess I've configured that while configuring the Pi, but I really don't know which one it is.
however this will just increase the wear on your SD card
so it will be even worse than not using zerofree?
the means you can compress the image better after [during] a dd of the filesystem.
How do I do that? .zip or something else? Does this "guarantee" I'll be able to burn the image to an SD card of the same size? (BTW, it's an 8GB card and I've already made an image with dd which is 7.97GB)
there are other ways of making useful copies of the complete filesystem
Can you give me an example? I'm basic terminal and Linux user. I don't know much about it, and looks like most options are rather complicated for my knowledge.
