Fri Jan 23, 2015 10:12 pm
Aydan wrote:AFAIK This type of current "limitation" is part of the USB Host specification.
"limitation" because it is software only and assumes the USB device will actually behave accordingly. Most devices don't. Unluckily the N900 does. E.g. it refuses to charge when plugged into a powered hub which is not connected to a host. I actually had to modify a cigarette lighter charger (resistor between USB data pins) because of that. The USB spec says that a dumb charger has to pull the data pins together. Most phones don't care and disrespect the USB spec (at least that's what the guys in the N900 forums told).
Regards
Aydan
Aha! That suggests it's actually expecting to be connected to a "USB charger port" which can supply (according to the specs.) up to 1A (as opposed to 500mA for a standard port). These are (were) meant to be "of a different colour" to standard ports. I've not come across any in practice (although I believe that the PiHUB**
does include such - maybe that's a solution). Many of the low-to-medium cost hubs (and my netbook, IIRC) appear have all (four) ports' power connections "in parallel", defeating the intended use of "Y-cables" and the "upto 500mA per port" spec.****
Trev.
http://swag.raspberrypi.org/products/pihub
http://www.cpmspectrepi.webspace.virgin ... esChk.html
