Pavo_46
NMEA MULTIPLEX
Fri Jan 23, 2015 4:29 pm
Hi there!!
This is my first time on a forum so bare with me. I am putting together a project using a raspberry pi and python to collect ASCII data from a GPS and echo sounder, to collect geolocated depths. Now i have hit a serious brick wall, i have managed to write the following script which (altering the baud rates) works for both devices, BUT heres the problem, how do I run both devices at the same time and output a single file? Or how do I automatically flip/flop between the two devices and collect one round of data at a time? (this is what I got so far)
from __future__ import print_function
import serial, io
addr  = '/dev/ttyUSB0'  # serial port to read data from
baud  = 9600            # baud rate for serial port
fname = 'log.dat'   # log file to save data in
fmode = 'a'             # log file mode = append
with serial.Serial(addr,baud) as pt, open(fname,fmode) as outf:
    spb = io.TextIOWrapper(io.BufferedRWPair(pt,pt,1),
        encoding='ascii', errors='ignore', newline='\r',line_buffering=True)
    spb.readline()  # throw away first line; likely to start mid-sentence (incomplete)
    while (1):
        x = spb.readline()  # read one line of text from serial port
        print (x,end='')    # echo line of text on-screen
        outf.write(x)       # write line of text to file
        outf.flush()        # make sure it actually gets written out
Thanks for any help,
Paul
topguy
Re: NMEA MULTIPLEX
Fri Jan 23, 2015 5:00 pm
Are there going to be two different devices, ttyUSB0 and ttyUSB1 when both devices are connected to the Pi at once ?
How often is the "echo sounder" sending out data ?
A GPS usually just send out data once every second. So what you could do is:
* open both devices for reading.
* start reading lines from GPS but use a timeout of lets say 250ms.
* when readline times out with no data you can assume that the GPS is pausing for its next batch of nmea lines.
* then start reading from the "echo sounder" also with a suitable timeout,
* after all the available data is read and you get a new timeout then switch back to GPS.
Another possible solution which is more advanced but more elegant:
* You start two threads where each thread is responsible for reading from one of the devices.
* The trick is then to figure out how to synchronize writing to the log file.
* I c/c++ i would probably use a global file descriptor and a semaphore to control that the two threads wasnt trying to write to the log file at the same time. I'm no Python expert so I dont feel up to recomending a proper method for Python.
Pavo_46
Re: NMEA MULTIPLEX
Fri Jan 23, 2015 5:19 pm
thanks for the reply!!
the echo sounder and gps will be connected to the Pi at the same time using usb-RS232 adapters. echo sounder is running at 1 Hz and with a baud of 115200, where as the GPS has a baud of 9600
ame
Re: NMEA MULTIPLEX
Fri Jan 23, 2015 7:24 pm
Pavo_46 wrote:thanks for the reply!!
You're not really multiplexing. You have two devices connected to two ports. Just open a different file handle for each one:
addr0  = '/dev/ttyUSB0'  # serial port to read data from GPS
baud0  = 9600
addr1  = '/dev/ttyUSB1'  # serial port to read data from echosounder
baud1  = 115200
In your program, open both ports, read data from each, write to file.
Pavo_46
Re: NMEA MULTIPLEX
Sat Jan 24, 2015 4:42 pm
hi there,
latest attempt (code below)
import serial, io
baud0 = 9600
baud1 = 115200
fname = 'RaspSurvey-Output.txt'
fmode = 'a'
with serial.Serial(addr0,baud0,addr1,baud1) as pt, open(fname,fmode) as outf:
    while (1):
when run in the console i receive the following error message:
  File "/home/pi/Desktop/dissertation_files/RaspSurvey.py", line 11, in <module>
  File "/usr/lib/python2.7/dist-packages/serial/serialutil.py", line 249, in __init__
    self.bytesize = bytesize
  File "/usr/lib/python2.7/dist-packages/serial/serialutil.py", line 331, in setByteSize
    if bytesize not in self.BYTESIZES: raise ValueError("Not a valid byte size: %r" % (bytesize,))
ValueError: Not a valid byte size: '/dev/ttyUSB1'
anyone have an idea of this?
thanks in advance
scotty101
Re: NMEA MULTIPLEX
Sat Jan 24, 2015 4:51 pm
You can't use serial.Serial in that way. Try something like this.
gps = serial.Serial(port1,baud1)
echo = serial.Serial(port2,baud2)
Electronic and Computer Engineer
Pi Interests: Home Automation, IOT, Python and Tkinter
Pavo_46
Re: NMEA MULTIPLEX
Sun Jan 25, 2015 6:47 pm
this has improved the issue
i used the following code
[code]from __future__ import print_function
import serial, io
baud0 = 9600
baud1 = 115200
GPS = serial.Serial(addr0,baud0)
ECHO = serial.Serial(addr1,baud1)
fmode = 'a'
with GPS and ECHO as pt, open(fname,fmode) as outf:
while (1):
outf.flush() # make sure it actually gets written out[/code]
this ran fine in the terminal, but only the echo sounder data was displayed and written to the output file, the gps data is being ignored, any help?
[code]>>>
$PRVAT,00.233,M,,*10
$PRVAT,00.233,M,,*10[/code]
paulie
Re: NMEA MULTIPLEX
Sun Jan 25, 2015 7:52 pm
I have an Adafruit ultimate GPS connected to the serial UART.
I use the gpsd package to collect the data, which allows multiple programs to share the data.
I believe it suggests the GPS tools package, which allows you to check your GPS is working.
Viewing the raw data will show you have the baud rate correct, and if you have a position fix.
When you have both devices sending valid data independently, you can then link them into your code.
It has been my custom to use Xeyes
Pavo_46
Re: NMEA MULTIPLEX
Sun Jan 25, 2015 9:31 pm
paulie wrote:I have an Adafruit ultimate GPS connected to the serial UART.
So what are you suggesting?
Re: NMEA MULTIPLEX
Sun Jan 25, 2015 10:09 pm
What happens when you reboot and /dev/ttyUSB0 gets switched with /dev/ttyUSB1 (because of the way the USB devices get enumerated during boot up)?
Can you post the output from a usb-devices command?
paulie
Re: NMEA MULTIPLEX
Mon Jan 26, 2015 12:47 am
Here is the website for gpsd
http://www.catb.org/gpsd/
gpsd is available in Raspbian.
Good instructions can be found here:
http://blog.retep.org/2012/06/18/gettin ... pberry-pi/
HTH
ame
Re: NMEA MULTIPLEX
Mon Jan 26, 2015 1:23 am
Pavo_46 wrote:this has improved the issue
<snip>
I think your 'with' statement syntax is not correct, and the whole thing is too terse for you to understand.
I don't think you should use gpsd yet, until you have something working. I also wouldn't worry about the order in which the serial ports are created until then (but it's worth knowing it's an issue you might have to deal with). Also, don't bother with threads.
There are several ways to solve your problem.
1. Have two programs. One for each device, writing to a common file. UNIX's file locking will prevent them writing at the same time.
2. Have one program which opens and listens to two serial ports. After getting valid data from each port, write two lines to the log file.
3. Replace one of the serial ports with gpsd.
4. ...
I suggest option 2, and that you get rid of 'with', and just open the two serial ports with their own file handle. Then, have an infinite loop that tries to read a line from the file handle. If a line is received, parse it. If it's bad data, or not the data you want, then discard it. Otherwise, write the parsed data to the log file.
To stop your program getting stuck waiting for data, use select() to see which serial port has data waiting, but even that is not needed the first time around, since you can be sure your devices will produce new data every second.
Pavo_46
Re: NMEA MULTIPLEX
Mon Jan 26, 2015 4:13 pm
4. ...
This sounds great and is exactly what I am aiming for, but having serious difficulty working out how to do this, mainly writing this loop as so far only worked with the with/while loop
ame
Re: NMEA MULTIPLEX
Mon Jan 26, 2015 10:25 pm
All right, here is a very basic framework to illustrate the idea. It doesn't use anything fancy, and assumes there are no errors. In fact, error checking is what makes your software great, so that it either does the Right Thing in case of an error, or at least doesn't crash.
#!/usr/bin/env python
import serial
# Specify serial ports
baud0 = 4800 #9600
baud1 = 4800 #115200
# Open serial ports
GPS = serial.Serial(addr0,baud0,timeout=1)
ECHO = serial.Serial(addr1,baud1,timeout=1)
while True:
        gps_data=GPS.readline()
        echo_data=ECHO.readline()
        if gps_data[0]=="$":
                print "GPS:  %s"%gps_data
        if echo_data[0]=="$":
                print "ECHO: %s"%echo_data
I tested this as I happened to have two USB GPS receivers. As you can see, it doesn't really do anything except open the ports (with a 1 second timeout) and continually read lines and print them.
To deal with a partial read (either junk character at the beginning, or halfway through an NMEA sentence) I do a simple check that the string begins with "$". All NMEA strings begin with "$" and end with a checksum. If you like, you can write a function that takes the string and verifies that the checksum is correct.
Presumably you wish to log the position from the GPS and the depth from the echo-sounder. Once you can get the strings into your program it's very easy to pull-apart the $GPRMC sentence from the GPS and the $PRVAT sentence from the echo-sounder. You can either store the whole sentence, or log lat/lon/depth (and date/time) to your logfile.
Pavo_46
Re: NMEA MULTIPLEX
Wed Jan 28, 2015 2:43 pm
ame wrote:All right, here is a very basic framework to illustrate the idea. It doesn't use anything fancy, and assumes there are no errors. In fact, error checking is what makes your software great, so that it either does the Right Thing in case of an error, or at least doesn't crash.
import serial
baud0 = 4800 #9600
# Open serial ports
while True:
Adding a output file in append mode and using the f.write and f.flush functions with your help has got me to my goal, thanks you very much!
ame
Re: NMEA MULTIPLEX
Wed Jan 28, 2015 7:59 pm
You're welcome. Glad to hear it's working.
Return to “Python”
