I am having some difficulties detecting button presses, sometimes they are detected if held long enough, and other times not at all. I am using regular buttons, but not those on the ADAfruit LCD backpack.
Maybe you all have some inputs:
#include <stdio.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <time.h>
#include <stdint.h>
#include <ctype.h>
#include <wiringPi.h>
#include <mcp23017.h>
#include <lcd.h>
#include "main.h"
#define DELAY_PERIOD 10
// Commands to retrieve information from the sensors
static const char *AM2302_CMD = "/usr/bin/dht22_interface";
static const char *DSPROBE_CMD = "cat /sys/devices/w1_bus_master1/28-*/w1_slave | sed -n 2p";
// Pins used (wiringPi numbers)
const int RELAY_PIN = 0;
const int UP_TMP_PIN = 6;
const int DN_TMP_PIN = 13;
const int MODE_PIN = 2;
const int BEEPER_PIN = 12;
// Default temperature to be used as a setpoint
static float set_point;
// Device mode {RUNNING, NOT_RUNNING}
static int device_mode;
// LCD handle
static int lcdHandle;
* usage(const char *progName)
* @brief program usage
* @param progName
* @return -1 for failure
int usage(const char *progName)
fprintf(stderr, "Usage: %s colour (0-7 where 0 is no backlight)\n", progName);
return EXIT_FAILURE;
* print_banner()
* @brief Prints app banner
static inline void print_banner()
printf("\nMaplePI GPIO/Monitoring App\n\n");
printf("Author: Ronnie brash (ron.brash@gmail.com)\n");
printf("------------------------------------------\n");
* setBacklightColour(int colour)
* @brief The colour outputs are inverted.
* @param color
static inline void setBacklightColour(int colour)
colour &= 7;
digitalWrite(AF_RED, !(colour & 1));
digitalWrite(AF_GREEN, !(colour & 2));
digitalWrite(AF_BLUE, !(colour & 4));
* adafruitLCDSetup(int colour)
* @param color
* @brief Setup the Adafruit board by making sure the additional pins are
* set to the correct modes, etc.
static void adafruitLCDSetup(int colour)
int i = 0;
lcdHandle = 0;
// Backlight LEDs
pinMode(AF_RED, OUTPUT);
pinMode(AF_GREEN, OUTPUT);
pinMode(AF_BLUE, OUTPUT);
setBacklightColour(colour);
// Input buttons
for (i = 0; i <= 4; ++i) {
pinMode(AF_BASE + i, INPUT);
pullUpDnControl(AF_BASE + i, PUD_UP); // Enable pull-ups, switches close to 0v
// Control signals
pinMode(AF_RW, OUTPUT);
digitalWrite(AF_RW, LOW); // Not used with wiringPi - always in write mode
// The other control pins are initialised with lcdInit ()
lcdHandle = lcdInit(2, SIZE_OF_LCD, 4, AF_RS, AF_E, AF_DB4, AF_DB5, AF_DB6, AF_DB7, 0, 0, 0, 0);
if (lcdHandle < 0) {
fprintf(stderr, "lcdInit failed\n");
exit(EXIT_FAILURE);
* mode_button()
* @brief Handles mode button functionality
static inline void mode_button(button_s * state)
if ((digitalRead(MODE_PIN) == LOW)) { // Wait for release
if (device_mode == RUNNING) {
setBacklightColour(RED_COLOR);
printf("Mode changed to NOT_RUNNING!\n");
device_mode = NOT_RUNNING;
} else {
printf("Mode changed to RUNNING!\n");
setBacklightColour(GREEN_COLOR);
device_mode = RUNNING;
state->waitForRelease = TRUE;
* up_temp_button()
* @brief Handles tmp up button functionality
static void up_temp_button(button_s * state)
if ((digitalRead(UP_TMP_PIN) == LOW)) {
printf("Up button pressed\n");
set_point += 0.5;
* down_temp_button()
* @brief Handles tmp down button functionality
static void down_temp_button(button_s * state)
if ((digitalRead(DN_TMP_PIN) == LOW)) {
printf("Down button pressed\n");
set_point -= 0.5;
* open_relay()
* @brief Opens relay at RELAY_PIN
static void open_relay()
printf("\topened relay\n");
digitalWrite(RELAY_PIN, HIGH);
* close_relay()
* @brief Closes relay at RELAY_PIN
static void close_relay()
printf("\tclosed relay\n");
digitalWrite(RELAY_PIN, LOW);
* manage_relay(float actual_temp)
* @brief manages relay
* @param actual_temp
static void manage_relay(float actual_temp)
if (actual_temp >= set_point) {
open_relay();
} else {
close_relay();
* setup_buttons()
* @brief Setup buttons to be used by the external
* user interface - to be manipulated by the user
static void setup_buttons()
* For each button:
* 1.) Set button as INPUT
* 2.) Enable pull-up resistor on button
pinMode(UP_TMP_PIN, INPUT);
pullUpDnControl(UP_TMP_PIN, PUD_UP);
pinMode(DN_TMP_PIN, INPUT);
pullUpDnControl(DN_TMP_PIN, PUD_UP);
pinMode(MODE_PIN, INPUT);
pullUpDnControl(MODE_PIN, PUD_UP);
pinMode(RELAY_PIN, OUTPUT);
* get_am2302_data(char *top_buffer)
* @brief Retrieves DS data
* @param top_buffer
static void get_am2302_data(char *top_buffer[])
// Retrieve out the AM2302 sensor data
FILE *am_file = NULL;
am_file = popen(AM2302_CMD, "r");
fgets(top_buffer, SIZE_OF_LCD, am_file);
pclose(am_file);
//printf("AM2302 output:%s\n", top_buffer);
* get_ds_data(float *actual_temp)
static void get_ds_data(float *actual_temp)
// Retrieve out DS probe sensor data
char probe_buffer[1024] = { 0 };
int len = 0;
int i = 0;
FILE *probe_file = NULL;
probe_file = popen(DSPROBE_CMD, "r");
fgets(probe_buffer, 1024, probe_file);
pclose(probe_file);
//printf("DS18B20 output:%s\n", probe_buffer);
// Raw buffer will be a string - read until a '='
len = strlen(probe_buffer);
for (i = len; i > 0; i--) {
if ((probe_buffer[i] == '=')) {
break;
// Convert the temperature string to a float
char tmp_buffer[8] = { 0 };
char *buff_ptr = (char *)&probe_buffer;
// Increment buffer to remove the '=' from the string
buff_ptr += 1;
memcpy(tmp_buffer, buff_ptr + i, (len - i));
// Convert string to a float and divide by 1000
(*actual_temp) = (1.8 * (atof(tmp_buffer) / 1000)) + 32;
* build_bottom_string( char *bottom_buffer, float actual_temp)
* @brief Builds bottom string to be displayed on LCD
* @param bottom_buffer
static inline void build_bottom_string(char *bottom_buffer[], float actual_temp)
snprintf(bottom_buffer, SIZE_OF_LCD, "%3.2f-%3.2f ", actual_temp, set_point);
memcpy(((char *)&bottom_buffer)+12, "Oui",3);
} else {
memcpy(((char *)&bottom_buffer)+13, "No",2);
* check_time(time_t old_time)
* @brief Checks for time
static int check_time(time_t * old_time)
// If this is the first time running, time will be 0;
if (old_time == 0) {
return (1);
time_t cur_time = time(0);
// Compare if difference in time is greater than X seconds
if ((difftime(cur_time, (time_t) old_time)) > 2) {
(*old_time) = cur_time;
return (1);
return (0);
* main(int argc, char *argv[])
* @brief main function
* @param argc
* @param argv
* @return 0 for success, -1 for error
int main(int argc, char *argv[])
button_s b_state = { 0 };
b_state.colour = RED_COLOR;
b_state.waitForRelease = FALSE;
set_point = DEFAULT_SETPOINT;
float actual_temp = 0;
time_t cur_time = 0;
char top_buffer[SIZE_OF_LCD] = { 0 };
char bottom_buffer[SIZE_OF_LCD] = { 0 }; //"123.45-123.45 {Ou,No}"
print_banner();
// Check arguments
if (argc != 2) {
return usage(argv[0]);
b_state.colour = atoi(argv[1]);
wiringPiSetup();
// Setup LCD
mcp23017Setup(AF_BASE, 0x20);
adafruitLCDSetup(b_state.colour);
// Set device mode to not running
// Initialize the user interface buttons (not on plate)
setup_buttons();
for (;;) {
// Open/Close Relay
manage_relay(actual_temp);
* Check time to reduce system calls which are polling
* the sensors - set to half of a second for default
if (check_time(&cur_time) > 0) {
// Retrieve sensor data through pipes
get_am2302_data(&top_buffer);
get_ds_data(&actual_temp);
// Output AM2302 data onto the top row of the LCD
lcdPosition(lcdHandle, 0, 0);
lcdPuts(lcdHandle, top_buffer);
// Build the final string (obviously not efficient)
build_bottom_string(&bottom_buffer, actual_temp);
// Output DS data & set_point onto the bottom row of the LCD
lcdPosition(lcdHandle, 0, 1);
lcdPuts(lcdHandle, bottom_buffer);
* Check buttons to change:
* 1.) temperature for set point (up or down)
* 2.) Mode of the device (Running or NOT_RUNNING)
* If buttons are still pushed then skip
if (b_state.waitForRelease) {
if ((digitalRead(UP_TMP_PIN) == LOW) || (digitalRead(DN_TMP_PIN) == LOW)
continue;
} else {
// Check GPIO/buttons for input
mode_button(&b_state);
up_temp_button(&b_state);
down_temp_button(&b_state);
return 0;
