More important is to show the output from an lsusb command (that's ell, ess, you, ess, bee).Onira wrote:guys, show your /etc/network/interfaces file
Shows us that everything is there and recognised.DougieLawson wrote:And the output from the lsusb command shows us what?
But it doesn't show that to me! Since I'm not in the room with you.ThreePointOneDour wrote:Shows us that everything is there and recognised.DougieLawson wrote:And the output from the lsusb command shows us what?
I did guess that's why you asked.DougieLawson wrote:But it doesn't show that to me! Since I'm not in the room with you.ThreePointOneDour wrote:Shows us that everything is there and recognised.DougieLawson wrote:And the output from the lsusb command shows us what?
$ lsusb
Bus 001 Device 004: ID 1d57:ad02 Xenta
Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 001 Device 006: ID 08bb:27c7 Texas Instruments Japan
Bus 001 Device 009: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA BridgeCode: Select all
$ cat /etc/network/interfacesCode: Select all
$ lsusbSorry!Pdog wrote:wow my post has been slightly hijacked here!
Ok, I can't keep it secret for much longer.....Onira wrote:Show us your outputCode: Select all
$ lsusb Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. Bus 001 Device 004: ID 1d57:ad02 Xenta Bus 001 Device 005: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB Bus 001 Device 006: ID 08bb:27c7 Texas Instruments Japan Bus 001 Device 009: ID 152d:2329 JMicron Technology Corp. / JMicron USA Technology Corp. JM20329 SATA Bridge
There is nothing to be afraid of showing it
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet dhcp
allow-hotplug wlan0
iface wlan0 inet manual
wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
wireless-power off
iface default inet dhcp
update_config=1
network={
ssid="yourWiFiSSIDgoeshere"
psk="yourWiFipasswordgoeshere"
}Code: Select all
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
0.0.0.0 192.168.x.ggg 0.0.0.0 UG 0 0 0 wlan0
192.168.x.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0Code: Select all
iface default inet static
address 192.168.x.ppp
gateway 192.168.x.ggg
netmask 255.255.255.0No its fine mate. I am just trying to post my information now, in the hope someone can help. I have a new SD card now and fresh install of OPENELEC from NOOBS 1.3.9ThreePointOneDour wrote:Sorry!Pdog wrote:wow my post has been slightly hijacked here!
Though, if we double up, maybe we can get more info to sort this out? If you'd rather me not, just say and I'll go
