slawekw79
TFT from old satnav
Fri Jan 16, 2015 7:46 pm
Hi
I've found old satnav with working screen but touch is gone. I thinking about use this TFT for my RPi B+. TFT model is LTE430WQ-F0C-0BU and i've found datasheet :
http://boundarydevices.com/wp-content/u ... WQ-F0C.pdf
It's possible to make working together TFT and my RPi?
Paeryn
Re: TFT from old satnav
Fri Jan 16, 2015 11:41 pm
Does the LCD have an HDMI / DVI-D / Composite Video input? If so then yes, just connect it. If not then you'll get the same answer as the 1,001 other people asking how to connect up a random LCD - pretty much zero chance unless you can build / buy a device that will convert one of the said formats into whatever format your LCD requires. The same way as you would if you wanted to connect it to your PC.
