I have those HY-SRF05 Sonar ranging devices to detect presence of objects. can they be used as Ultrasound imagining equipment they used in the medical areas? I am looking for an off the shell , inexpensive design that transmit and receive well through human membrane, and tissues.
Transducers
In some respects, the transducer is the most critical component in any ultrasonic imaging system. In other words, such is the state of the art in systems such as electronic circuitry and display technology that it is the performance of the transducer which determines how closely the limits imposed by the characteristics of the tissues themselves can be approached.
Nowadays, the transducers which are in clinical use almost exclusively use a piezoelectric material, of which the artificial ferroelectric ceramic, lead zirconate titanate (PZT), is the most common. The ideal transducer for ultrasonic imaging would have a characteristic acoustic impedance perfectly matched to that of the (human) body, have high efficiency as a transmitter and high sensitivity as a receiver, a wide dynamic range and a wide frequency response for pulse operation. PZT has a much higher characteristic impedance than that of water but it can be made to perform quite well by the judicious use of matching layers consisting of materials with intermediate characteristic impedances. Even better performance can be obtained by embedding small particles or shaped structures of PZT in a plastic to form a composite material: this has a lower characteristic impedance than that of PZT alone, although it has similar ferroelectric properties.
Polyvinylidene difluoride (PVDF) is a plastic which can be polarized so that it has piezoelectric properties. The piezoelectric effect can be enhanced by the addition of small quantities of appropriate chemicals. The advantages of this material are that it has a relatively low characteristic impedance and broad frequency bandwidth; it is fairly sensitive as a receiver but rather inefficient as a transmitter.
Piezoelectric transducers are normally operated over a band of frequencies centred at their resonant frequency. The resonant frequency of a transducer occurs when it is half a wavelength in thickness. Typically, a PZT transducer resonant at a frequency of, say, 3 MHz is about 650 μm thick and this means that it is sufficiently mechanically robust for simple, even manual, fabrication techniques to be employed in probe construction. Higher frequency transducers are proportionally thinner and, consequently, more fragile.
The potential of capacitive micromachined ultrasonic transducers (cMUTs) at least partially to replace PZT and PVDF devices in ultrasonic imaging is the subject of current research. A cMUT consists of a micromachined capacitor, typically mounted on a silicon substrate and with a thin electroded membrane as the other plate of the capacitor: this acts as the active surface of the transducer. A dc voltage is applied between the plates of the device; the application of an ac voltage causes the membrane to transmit a corresponding oscillatory force, while a received wave causes a corresponding change in the spacing between the plates, thus generating an electrical signal. cMUTs are adequately sensitive as receivers, but need high voltages to be effective transmitters. Some of the potential advantages of these devices are that they can be fabricated into arrays with integrated electronics and, if manufactured in large quantities, could be relatively inexpensive.
