ncguk
Wiring up and reading 1Hz square wave output from RTC
Wed Jan 14, 2015 12:08 pm
I've scoured Google for a solution to this to no avail.
I'm trying to hook up the 1Hz square wave output of a DS3231 RTC breakout board to GPIO18 (pin 12) of the Pi. As per information on the web I've turned on the wave output (theoretically, using an Arduino sketch) and added a resistor between SQW and VCC. "bcm2708.pps_gpio_pin=18" has been added to /boot/cmdline.txt, "pps-gpio" has been added to /etc/modules and /pps0 shows up in /dev. However, when I run "sudo ppstest /dev/pps0" the only output I receive is "time_pps_fetch() error -1 (Connection timed out)".
I suspect I'm missing something very simple or I've got something drastically wrong. Can anyone shove me in the right direction? Thanks.
Re: Wiring up and reading 1Hz square wave output from RTC
Wed Jan 14, 2015 12:18 pm
https://github.com/raspberrypi/linux/pull/717
Have you missed adding bcm2708.pps_gpio_enable=1 to cmdline?
This is a doctor free zone.
ncguk
Wed Jan 14, 2015 1:43 pm
DougieLawson wrote:https://github.com/raspberrypi/linux/pull/717
That syntax was changed by the developers at the last minute to what I quote above, a way which has worked successfully for me with GPS 1PPS output, so it's nothing that simple (if only it were).
Wed Jan 14, 2015 1:54 pm
Do you get any PPS messages in the kernel message log (dmesg command)?
There's a good article on doing this stuff with a GPS receiver here: http://www.satsignal.eu/ntp/Raspberry-Pi-NTP.html
ncguk
Wed Jan 14, 2015 2:24 pm
DougieLawson wrote:Do you get any PPS messages in the kernel message log (dmesg command)?
dmesg | grep pps shows:
[    0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708.boardrev=0x12 bcm2708.serial=0xcd587ca6 smsc95xx.macaddr=B8:27:EB:58:7C:A6 bcm2708_fb.fbswap=1 bcm2708.disk_led_gpio=47 bcm2708.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0xec00000 vc_mem.mem_size=0x10000000  dwc_otg.lpm_enable=0 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline rootwait bcm2708.pps_gpio_pin=18
[    0.029352] bcm2708: GPIO 18 setup as pps-gpio device
[   10.829070] pps_core: LinuxPPS API ver. 1 registered
[   10.830658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <[email protected]>
[   10.837862] pps pps0: new PPS source pps-gpio.18
[   10.839637] pps pps0: Registered IRQ 188 as PPS source
Thanks for that. I've referred to that page many times while playing about with GPS/PPS and I can get that sort of set-up to work pretty easily. What I'm trying to do the the RTC square wave output is really for tinkering purposes only, and possibly to compare the two.
ncguk
Wed Jan 14, 2015 7:50 pm
Never mind – the cause of the problem was operator error. Though I believed I had enable the square wave output in the DS3231 I in fact hadn't.
Using this library: https://github.com/radekw/Arduino/tree/ ... /Chronodot
And this Arduino sketch:
#include <Wire.h>
#include <Chronodot.h>
// create global chronodot instance
Chronodot chronodot = Chronodot();
void setup() {
  Serial.begin(9600);
void loop() {
chronodot.setSQW(1);
I was able to correctly enable the square wave output at 1Hz. I have no doubt there is a way to do this with Python on the Pi but in this instance the Arduino saved the day. Well, the second.
