tskwara
New Proto Armour for Raspberry Pi B+ and Camera
Thu Jan 08, 2015 8:30 pm
We are proud to announce the release of Proto Armour for Raspberry Pi B+ and Camera, the unique and rugged aluminum case for the Raspberry Pi Model B+ and Camera Module! Initial availability is limited and is on a first come, first serve basis, so order quickly!
With last year's release of the RPi Model B+ board, we got to work on an enclosure for the B+ right away, and we released Proto Armour for Raspberry Pi B+ last fall. Now we are taking the wraps off the updated Proto Armour for Raspberry Pi B+ and Camera case. This new case provides the same great fit and protection you’ve loved about our Proto Armour for Raspberry Pi and Camera case, only now it is tailored specifically for the RPi Model B+.
Both the latest original B and the new B+ versions of the enclosure incorporate precision camera module mounting features that are compatible with upcoming external lens adapters - fasten your seatbelt folks! Even more good news is that any accessories you’ve purchased for your other Proto Armour for Raspberry Pi cases should still work fine – the footprint of the new case is exactly the same, it’s just the output areas that have changed. We will continue to sell our cases for other models of the Raspberry Pi computers, so no matter which version you are trying to protect, you’ll have our high quality cases to keep them safe.
Shown with Accessories
Black Anodized Finish
Plain Aluminum Finish
MobileApp Systems
Mobile Applications on a Mission
Makers of Proto Armour for Raspberry Pi
Explore Proto Armour / www.protoarmour.com
bmstrong
Re: New Proto Armour for Raspberry Pi B+ and Camera
Thu Feb 05, 2015 6:00 pm
I love these designs from you guys. Will these fit the RP2?
tskwara
Thu Feb 05, 2015 6:03 pm
Yes it works with the RPi 2! The intent is to push forward with new designs using the 40-pin header. We have the Raspberry Pi 2 in-house now, so all development is done using the newest board, but with compatibility testing using other boards.
MobileApp Systems
bmstrong
Sun Feb 22, 2015 9:43 pm
Interesting. Any interest in making a slim version with cut down ends for quicker access to the MicroSD and USB ports?
http://store.mobileappsystems.com/110149/
tskwara
Sun Feb 22, 2015 10:27 pm
Sure, but can only do this with a volume commitment. Any thoughts on how many you need?
MobileApp Systems
