The Berryboot menu config.txt alos has nothing...
Using SSH gives me an error where it can't find anything in /flash so I can't get to the config.txt!
HelP!
(i know, normally in a pure OpenELEC installation or in an embedded installation inside of NOOBS, the config.txt file is in the /flash folder. and you have to remount that mountpoint in read-write-mode, to be able to change the existing config.txt inside that folderClick on the ”»” button to the right of the screen to see all options
mount /flash -o rw,remount
