I have a Raspi B installed in a basic case. I am not currently using the GPIO's, so I didn't realize when selecting a case that they were basically blocked since the case is too close to the pins to allow a standard 1P Dupont jumper to be installed. I tried to connect a couple jumper wires and found the case did not quite close and the jumper wires we basically pinched at a 90 degree angle. I took a couple jumpers and sanded off as much plastic as I could which looks like it might mostly work, but I'm not very happy with the result since it only saves maybe 1/8".
Does anyone make low profile jumpers? If not, the only real options I see are cutting a slot in the case for the GPIO's, grinding the connectors down even more, or finding a different case.
This is my case:
http://www.vetco.net/catalog/product_in ... s_id=15176
As you can see, the case has a slot for installing a side mount GPIO connector, but I don't need a fully populated header.
