rgameros
Wirelessly connecting Raspberry Pi to a Desktop
Thu Jan 01, 2015 1:16 am
I was wondering if you can connect to a Raspberry Pi via wifi, but without internet. Can I use a router (without internet) to create a local network that my desktop and the Raspberry Pis can connect to and communicate with each other through the router? I would like to use VNC to access the RPi's GUI. Any help would be appreciated!
I have seen guides about connecting directly via an ethernet cable between a desktop and a Raspberry Pi, but I would like to do it without a cable.
iinnovations
Re: Wirelessly connecting Raspberry Pi to a Desktop
Thu Jan 01, 2015 3:24 am
You can either connect directly by having your Pi act as an access point (AP mode), or simply connect both your computer and your Pi to a router. No internet required, just the IP that the router assigns your Pi.
C
CuPID Controls :: Open Source browser-based sensor and device control
interfaceinnovations.org/cupidcontrols.html
cupidcontrols.com
Gomez
Thu Jan 01, 2015 3:25 am
Acess this tutorial and you will be able to connect to your RPi with a ethernet cable from your computer directly to the raspberry pi without the need of the router.. but it might be easier with the router trough LAN.
Have fun :)
Thu Jan 01, 2015 5:52 am
Gomez wrote:Acess this tutorial and you will be able to connect to your RPi with a ethernet cable from your computer directly to the raspberry pi without the need of the router.. but it might be easier with the router trough LAN.
Have fun :)
""was wondering if you can connect to a Raspberry Pi via wifi""
The OP seems to want WiFi :roll:
RPi 4B 4GB (SSD Boot)..
