haribofan
Squeezelite as multi instance
Tue Dec 30, 2014 7:47 am
I have a big problem with my raspberry and squeezelite.
I have run squeezelite as multi instance. (2x)
For a few hours, it runs normally with the same CPU load.
After that rises the CPU load by one instance and the other decreases and there is problems with the audio output.
When I restart the instance with the lower cpu load it is normal for some hours. (both instances)
Return to “Media centres”
