drgeoff wrote:donest wrote:
I make no apology for labouring this point. At no point have you said that you are inserting the micro-SD card into the micro-SD slot on the underneath of the RPi.
At this point *I* am the one who should be apologizing! I had repeatedly stated that the micro SD card plugs into an adaptor, that in turn plugs into a reader, that is inserted into the USB port on my PC for formatting and installing NOOBS. I figured that the whole assembly (card, adaptor, and reader) would then plug into one of the USB ports on the Pi!
Noticing your message tonight, I more closely examined the Pi. There is a slot for a micro-SD card, but was rather inaccessible due to the translucent case that i had mentioned. I had to pry the case apart and insert the card into the proper slot, and voila! All is working now.
The full size SD card that I bought with NOOBS installed is pretty useless except to save in case anything goes wrong, and I need to reinstall the os.
Thanks for all of your replies. They really did help!
