Sun Dec 28, 2014 5:18 pm
Hi there folks, I just recently purchased a raspberry pi b+ to run a owncloud server. I am running the latest version of Raspbian wheezy. I was able to install owncloud using a script from petrockblogs github page called owncloudpie. I am albe to navigate to the owncloud url and see the owncloud log in page. On this log in page it ask you to set up your database storage. I am trying to use an external HDD usb storage drive. will lsblk or df -h show me the correct name I need to be using for the hard drive? It shows me /media/Seagate External Drive but not sure if that is the full name or not. I need to know the correct name for the external drive so I can give it the correct permissions and and so I can also enter into the storage field on the owncloud setup. Also will owncloud and/or raspbian support NTFS file system or do I need to format to ext4 or fat32? Any help is much appreciated, thanks so much for reading my post. (to mods, if there is a better category this post would belong in please don't mind moving it)
