davidcoton
Autorun Python code on TFT
Sat Dec 27, 2014 8:48 pm
I have a Model B with an Adafruit TFT attached. It's going to be a heating controller in a church (if I ever manage to jump all the hurdles).
I've got code that runs on the display, but I'm having trouble getting it to autorun. I added to /etc/rc.local:
python3 /home/python/heating.py &
which seems to start the code, but it promptly aborts, leaving the x screen running and showing an error in the (hdmi) text terminal:
_tkinter.TclError: No display name and no $DISPLAY environment variable
I've used Linux for some time, but still have no idea how to set the name and/or env var in an appropriate place -- or how to find what the correct value should be. Any hints?
Signature retired
broo0ose
Re: Autorun Python code on TFT
Sat Dec 27, 2014 10:57 pm
I'd add it to
/etc/xdg/lxsession/LXDE/autostart
Back up the file, you can remove the other lines and add your command with an @ at the beginning. Have a look at the file and you'll understand what I mean
davidcoton
Sun Dec 28, 2014 12:01 am
Thanks for the reply, but it doesn't work that way either. It will wait for a login on the console -- despite autologin having been enabled (at least I think it was). I can't even get LXDE to start reliably now. If I try starting my program from the console, I get the same problem as in the first post.
I'm getting very discouraged -- autostart ought to be a minor part of the project, but I'm going to waste all my available time on it. It has been three months since I last had any programming time and it looks like I will never get enough time to make it all work. We may have to find another control system instead of building one on RPi.
Signature retired
broo0ose
Sun Dec 28, 2014 7:01 pm
Have you used
sudo raspi-config
to force gui mode rather than command line.
That should do the auto-login for you.
latki8
Sat Jan 03, 2015 12:08 am
If it is of any help, I was interested in trying this out myself (tkinter, not heating controller). I agree the tkinter error is probably because there is no x environment, ie the python code is running on the basic console function, but I have followed what has been suggested above and it all works fine as far as I can see and even with no HDMI screen connected, the python tkinter code is still running. The only problem I have is that my Noobs SD card still has all the other OS on it and the boot process won't continue until I press escape - annoying, but I want to keep my options open for now. In case it isn't clear, I don't have an Adafruit screen either.
Return to “Advanced users”
