Sat Jan 03, 2015 7:57 pm
matbos wrote:Thanks for your reply, I have an old model B (250mb ram). Would the power suply i mentioned work on it? Even if only for two hours?
So long as the Pi + any USB peripherals are drawing ~700mA (and your power bank still provides ~4.75V) then you ought to achieve ~2 hours** running time. The disadvantage of that style of powerbank is that they do not provide any indication of the charge remaining (whereas the two I use have a four or five led "bargraph-style" display**) and you may suffer power failure when you least expect it!
Trev.
** Which was showing ~half-charge at the end of the "~2hr afternoon jam" I mentioned in my previous post.
