A few days ago I've upgraded Raspberry Pi B+ arch linux and since then I cannot run java, because if Itry to execute it, I get:
What is going on?-bash: /usr/bin/java: cannot execute binary file: Exec format error
archlinux-java statusIt seems installation is ok, but I cannot run java from terminal.Available Java environments:
java-7-openjdk (default)
strace -f -v -s 60 -o java.strace java
Welcome to Arch Linux ARM
Website: http://archlinuxarm.org
Forum: http://archlinuxarm.org/forum
IRC: #archlinux-arm on irc.Freenode.net
Last login: Fri Dec 26 14:53:41 2014 from internet-xxxx.si
[root@octopustest ~]# strace -f -v -s 60 -o java.strace java
-bash: strace: command not found
[root@octopustest ~]# pacman -S strace
resolving dependencies...
looking for inter-conflicts...
Packages (1): strace-4.9-1
Total Download Size: 0.09 MiB
Total Installed Size: 0.28 MiB
:: Proceed with installation? [Y/n] y
:: Retrieving packages ...
strace-4.9-1-armv6h 90.0 KiB 750K/s 00:00 [#######################################] 100%(1/1) checking keys in keyring [#######################################] 100%(1/1) checking package integrity [#######################################] 100%(1/1) loading package files [#######################################] 100%(1/1) checking for file conflicts [#######################################] 100%(1/1) checking available disk space [#######################################] 100%(1/1) installing strace [#######################################] 100%[root@octopustest ~]# strace -f -v -s 60 -o java.strace java
strace: exec: Exec format error
[root@octopustest ~]# ls -l /usr/bin/strace /usr/bin/java /usr/bin/bash
-rwxr-xr-x 1 root root 652396 Oct 6 13:20 /usr/bin/bash
lrwxrwxrwx 1 root root 37 Nov 2 17:43 /usr/bin/java -> /usr/lib/jvm/default-runtime/bin/java
-rwxr-xr-x 1 root root 243676 Aug 17 09:13 /usr/bin/strace
[root@octopustest ~]# whoami
root
pacman -S jre7-openjdk-headlessHow do I uninstall current java with all dependencies?warning: jre7-openjdk-headless-7.u71_2.5.3-3 is up to date -- reinstalling
Packages (1): jre7-openjdk-headless-7.u71_2.5.3-3
Total Installed Size: 44.58 MiB
(1/1) checking keys in keyring [############################################################] 100%
(1/1) checking package integrity [############################################################] 100%
(1/1) loading package files [############################################################] 100%
(1/1) checking for file conflicts [############################################################] 100%
error: failed to commit transaction (conflicting files)
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/java exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/keytool exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/orbd exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/pack200 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/rmid exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/rmiregistry exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/servertool exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/tnameserv exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/bin/unpack200 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/headless/libmawt.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/jli/libjli.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/jvm.cfg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libattach.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libawt.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libdt_socket.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libfontmanager.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libhprof.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libinstrument.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libj2gss.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libj2krb5.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libj2pcsc.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libj2pkcs11.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjaas_unix.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjava.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjava_crw_demo.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjavagtk.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjavajpeg.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjavalcms.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjawt.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjdwp.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjsdt.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjsig.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libjsound.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libmanagement.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libmlib_image.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnet.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnio.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libnpt.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libsctp.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libunpack.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libverify.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/libzip.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/server/Xusage.txt exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/server/libjsig.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/arm/server/libjvm.so exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/calendars.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/charsets.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/classlist exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/cmm/CIEXYZ.pf exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/cmm/GRAY.pf exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/cmm/LINEAR_RGB.pf exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/cmm/PYCC.pf exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/cmm/sRGB.pf exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/content-types.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/currency.data exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/ext/dnsns.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/ext/localedata.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/ext/meta-index exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/ext/sunjce_provider.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/ext/sunpkcs11.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/ext/zipfs.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/flavormap.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/fontconfig.bfc exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/fontconfig.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/cursors.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/invalid32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/motif_CopyDrop32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/motif_CopyNoDrop32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/motif_LinkDrop32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/motif_LinkNoDrop32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/motif_MoveDrop32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/images/cursors/motif_MoveNoDrop32x32.gif exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/jce.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/jexec exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/jsse.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/jvm.hprof.txt exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/logging.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/management-agent.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/management/jmxremote.access exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/management/jmxremote.password exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/management/management.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/management/snmp.acl exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/meta-index exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/net.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/psfont.properties.ja exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/psfontj2d.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/resources.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/rhino.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/rt.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/security/US_export_policy.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/security/cacerts exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/security/java.policy exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/security/java.security exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/security/local_policy.jar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/security/nss.cfg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/sound.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/tz.properties exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Abidjan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Accra exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Addis_Ababa exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Algiers exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Asmara exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Bamako exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Bangui exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Banjul exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Bissau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Blantyre exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Brazzaville exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Bujumbura exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Cairo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Casablanca exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Ceuta exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Conakry exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Dakar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Dar_es_Salaam exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Djibouti exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Douala exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/El_Aaiun exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Freetown exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Gaborone exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Harare exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Johannesburg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Kampala exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Khartoum exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Kigali exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Kinshasa exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Lagos exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Libreville exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Lome exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Luanda exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Lubumbashi exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Lusaka exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Malabo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Maputo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Maseru exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Mbabane exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Mogadishu exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Monrovia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Nairobi exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Ndjamena exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Niamey exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Nouakchott exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Ouagadougou exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Porto-Novo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Sao_Tome exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Tripoli exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Tunis exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Africa/Windhoek exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Adak exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Anchorage exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Antigua exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Araguaina exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Buenos_Aires exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Catamarca exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Cordoba exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Jujuy exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/La_Rioja exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Mendoza exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Rio_Gallegos exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Salta exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/San_Juan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/San_Luis exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Tucuman exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Argentina/Ushuaia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Asuncion exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Atikokan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Bahia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Bahia_Banderas exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Barbados exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Belem exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Belize exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Blanc-Sablon exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Boa_Vista exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Bogota exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Boise exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Cambridge_Bay exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Campo_Grande exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Cancun exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Caracas exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Cayenne exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Cayman exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Chicago exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Chihuahua exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Costa_Rica exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Creston exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Cuiaba exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Curacao exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Danmarkshavn exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Dawson exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Dawson_Creek exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Denver exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Detroit exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Edmonton exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Eirunepe exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/El_Salvador exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Fortaleza exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Glace_Bay exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Godthab exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Goose_Bay exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Grand_Turk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Guatemala exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Guayaquil exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Guyana exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Halifax exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Havana exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Hermosillo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Indianapolis exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Knox exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Marengo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Petersburg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Tell_City exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Vevay exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Vincennes exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Indiana/Winamac exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Inuvik exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Iqaluit exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Jamaica exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Juneau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Kentucky/Louisville exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Kentucky/Monticello exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/La_Paz exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Lima exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Los_Angeles exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Maceio exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Managua exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Manaus exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Martinique exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Matamoros exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Mazatlan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Menominee exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Merida exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Metlakatla exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Mexico_City exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Miquelon exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Moncton exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Monterrey exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Montevideo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Montreal exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Nassau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/New_York exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Nipigon exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Nome exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Noronha exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/North_Dakota/Beulah exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/North_Dakota/Center exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/North_Dakota/New_Salem exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Ojinaga exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Panama exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Pangnirtung exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Paramaribo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Phoenix exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Port-au-Prince exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Port_of_Spain exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Porto_Velho exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Puerto_Rico exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Rainy_River exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Rankin_Inlet exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Recife exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Regina exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Resolute exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Rio_Branco exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Santa_Isabel exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Santarem exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Santiago exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Santo_Domingo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Sao_Paulo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Scoresbysund exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Sitka exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/St_Johns exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Swift_Current exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Tegucigalpa exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Thule exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Thunder_Bay exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Tijuana exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Toronto exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Vancouver exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Whitehorse exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Winnipeg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Yakutat exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/America/Yellowknife exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Casey exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Davis exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/DumontDUrville exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Macquarie exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Mawson exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Palmer exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Rothera exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Syowa exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Troll exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Antarctica/Vostok exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Aden exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Almaty exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Amman exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Anadyr exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Aqtau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Aqtobe exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Ashgabat exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Baghdad exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Bahrain exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Baku exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Bangkok exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Beirut exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Bishkek exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Brunei exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Choibalsan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Chongqing exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Colombo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Damascus exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Dhaka exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Dili exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Dubai exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Dushanbe exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Gaza exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Harbin exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Hebron exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Ho_Chi_Minh exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Hong_Kong exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Hovd exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Irkutsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Jakarta exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Jayapura exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Jerusalem exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kabul exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kamchatka exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Karachi exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kashgar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kathmandu exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Khandyga exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kolkata exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Krasnoyarsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kuala_Lumpur exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kuching exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Kuwait exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Macau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Magadan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Makassar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Manila exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Muscat exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Nicosia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Novokuznetsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Novosibirsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Omsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Oral exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Phnom_Penh exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Pontianak exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Pyongyang exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Qatar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Qyzylorda exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Rangoon exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Riyadh exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Riyadh87 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Riyadh88 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Riyadh89 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Sakhalin exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Samarkand exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Seoul exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Shanghai exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Singapore exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Taipei exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Tashkent exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Tbilisi exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Tehran exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Thimphu exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Tokyo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Ulaanbaatar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Urumqi exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Ust-Nera exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Vientiane exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Vladivostok exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Yakutsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Yekaterinburg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Asia/Yerevan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Azores exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Bermuda exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Canary exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Cape_Verde exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Faroe exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Madeira exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Reykjavik exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/South_Georgia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/St_Helena exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Atlantic/Stanley exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Adelaide exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Brisbane exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Broken_Hill exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Currie exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Darwin exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Eucla exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Hobart exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Lindeman exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Lord_Howe exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Melbourne exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Perth exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Australia/Sydney exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/CET exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/CST6CDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/EET exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/EST exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/EST5EDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+1 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+10 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+11 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+12 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+2 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+3 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+4 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+5 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+6 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+7 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+8 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT+9 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-1 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-10 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-11 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-12 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-13 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-14 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-2 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-3 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-4 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-5 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-6 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-7 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-8 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/GMT-9 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/UCT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Etc/UTC exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Amsterdam exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Andorra exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Athens exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Belgrade exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Berlin exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Brussels exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Bucharest exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Budapest exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Chisinau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Copenhagen exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Dublin exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Gibraltar exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Helsinki exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Istanbul exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Kaliningrad exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Kiev exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Lisbon exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/London exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Luxembourg exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Madrid exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Malta exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Minsk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Monaco exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Moscow exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Oslo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Paris exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Prague exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Riga exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Rome exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Samara exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Simferopol exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Sofia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Stockholm exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Tallinn exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Tirane exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Uzhgorod exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Vienna exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Vilnius exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Volgograd exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Warsaw exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Zaporozhye exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Europe/Zurich exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/GMT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/HST exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Antananarivo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Chagos exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Christmas exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Cocos exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Comoro exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Kerguelen exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Mahe exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Maldives exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Mauritius exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Mayotte exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Indian/Reunion exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/MET exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/MST exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/MST7MDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/PST8PDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Apia exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Auckland exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Chatham exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Chuuk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Easter exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Efate exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Enderbury exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Fakaofo exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Fiji exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Funafuti exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Galapagos exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Gambier exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Guadalcanal exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Guam exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Honolulu exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Kiritimati exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Kosrae exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Kwajalein exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Majuro exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Marquesas exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Midway exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Nauru exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Niue exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Norfolk exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Noumea exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Pago_Pago exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Palau exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Pitcairn exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Pohnpei exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Port_Moresby exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Rarotonga exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Saipan exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Tahiti exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Tarawa exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Tongatapu exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Wake exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/Pacific/Wallis exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/AST4 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/AST4ADT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/CST6 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/CST6CDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/EST5 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/EST5EDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/HST10 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/MST7 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/MST7MDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/PST8 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/PST8PDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/YST9 exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/SystemV/YST9YDT exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/WET exists in filesystem
jre7-openjdk-headless: /usr/lib/jvm/java-7-openjdk/jre/lib/zi/ZoneInfoMappings exists in filesystem
jre7-openjdk-headless: /usr/share/licenses/java7-openjdk/ASSEMBLY_EXCEPTION exists in filesystem
jre7-openjdk-headless: /usr/share/licenses/java7-openjdk/LICENSE exists in filesystem
jre7-openjdk-headless: /usr/share/licenses/java7-openjdk/THIRD_PARTY_README exists in filesystem
jre7-openjdk-headless: /usr/share/licenses/jre7-openjdk-headless exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/java.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/keytool.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/orbd.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/pack200.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/rmid.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/rmiregistry.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/servertool.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/tnameserv.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/ja/man1/unpack200.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/java.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/keytool.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/orbd.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/pack200.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/rmid.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/rmiregistry.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/servertool.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/tnameserv.1.gz exists in filesystem
jre7-openjdk-headless: /usr/share/man/man1/unpack200.1.gz exists in filesystem
Errors occurred, no packages were upgraded.
strace and perl execute without problems:sdjf wrote:I am worried you may end up breaking other packages if you remove all files it depends on. Read the man page for pacman and the following
https://wiki.archlinux.org/index.php/pacman
https://wiki.archlinux.org/index.php/Pacman_tips
Since you are getting the same error with strace as with java, and strace only has one dependency, perl, it may be better to see if reinstalling strace solves the exec format error problem. If it does not, then I am thinking there must be some other problem, since you are getting this with more than just java.
perl -vand[root@octopustest ~]# perl -v
This is perl 5, version 20, subversion 1 (v5.20.1) built for armv6l-linux-thread-multi
Copyright 1987-2014, Larry Wall
Perl may be copied only under the terms of either the Artistic License or the
GNU General Public License, which may be found in the Perl 5 source kit.
Complete documentation for Perl, including FAQ lists, should be found on
this system using "man perl" or "perldoc perl". If you have access to the
Internet, point your browser at http://www.perl.org/, the Perl Home Page.
straceIs it safe if I manualy delete[root@octopustest ~]# strace
usage: strace [-CdffhiqrtttTvVxxy] [-I n] [-e expr]...
[-a column] [-o file] [-s strsize] [-P path]...
-p pid... / [-D] [-E var=val]... [-u username] PROG [ARGS]
or: strace -c[df] [-I n] [-e expr]... [-O overhead] [-S sortby]
-c -- count time, calls, and errors for each syscall and report summary
-C -- like -c but also print regular output
-w -- summarise syscall latency (default is system time)
-d -- enable debug output to stderr
-D -- run tracer process as a detached grandchild, not as parent
-f -- follow forks, -ff -- with output into separate files
-i -- print instruction pointer at time of syscall
-q -- suppress messages about attaching, detaching, etc.
-r -- print relative timestamp, -t -- absolute timestamp, -tt -- with usecs
-T -- print time spent in each syscall
-v -- verbose mode: print unabbreviated argv, stat, termios, etc. args
-x -- print non-ascii strings in hex, -xx -- print all strings in hex
-y -- print paths associated with file descriptor arguments
-h -- print help message, -V -- print version
-a column -- alignment COLUMN for printing syscall results (default 40)
-b execve -- detach on this syscall
-e expr -- a qualifying expression: option=[!]all or option=[!]val1[,val2]...
options: trace, abbrev, verbose, raw, signal, read, write
-I interruptible --
1: no signals are blocked
2: fatal signals are blocked while decoding syscall (default)
3: fatal signals are always blocked (default if '-o FILE PROG')
4: fatal signals and SIGTSTP (^Z) are always blocked
(useful to make 'strace -o FILE PROG' not stop on ^Z)
-o file -- send trace output to FILE instead of stderr
-O overhead -- set overhead for tracing syscalls to OVERHEAD usecs
-p pid -- trace process with process id PID, may be repeated
-s strsize -- limit length of print strings to STRSIZE chars (default 32)
-S sortby -- sort syscall counts by: time, calls, name, nothing (default time)
-u username -- run command as username handling setuid and/or setgid
-E var=val -- put var=val in the environment for command
-E var -- remove var from the environment for command
-P path -- trace accesses to path
directory?/usr/lib/jvm
