shingster
Which make for Raspberry pi b+
Thu Dec 18, 2014 4:42 pm
Hi
As I recently explained in another post im doing a project for university that requires me to use a PI b+
Im going to use the Kali Linux OS for my project. I know that the B+ uses micro SD cards for storage unlike the first two models.
So i wanted to ask which makes are the best ones as i know that not all of them will work on the PI for whatever reason ?
mikronauts
Re: Which make for Raspberry pi b+
Thu Dec 18, 2014 4:51 pm
Lately I've been using ADATA 16GB Class 10 UCH-1 cards. No issues so far.
shingster
Thu Dec 18, 2014 4:53 pm
Will micro SDHC cards work on the Pi B+ by any chance?
Because the shops these days have more SDHC cards than the regular Micro SD cards
RaTTuS
Contact: Twitter YouTube
Thu Dec 18, 2014 4:55 pm
the only one that don't work are fake ones .... IME
class 4 / 6 are probably about the best bang for buck
Covfefe
shingster
Thu Dec 18, 2014 4:58 pm
I was thinking of getting either the Adata class 10 micro SDHC AUSDH16GUICL10-R cards or the Kingston SDC10/16GB cards for my project
Thu Dec 18, 2014 5:01 pm
shingster wrote:I was thinking of getting either the Adata class 10 micro SDHC AUSDH16GUICL10-R cards or the Kingston SDC10/16GB cards for my project
http://www.raspberrypi.org/forums/viewt ... 46&t=81743
RPi 4B 4GB (SSD Boot)..
Thu Dec 18, 2014 5:12 pm
shingster wrote:Will micro SDHC cards work on the Pi B+ by any chance?
The only ones that will cause a struggle are cards that are over 32GB as they need reformatting before you can use them with a Raspberry Pi (of any flavour).
W. H. Heydt
Thu Dec 18, 2014 5:41 pm
You'd have a bloody hard job making a full size SDCard fit the microSD slot on a B+.
In another thread there was a picture of a microSD to full sized SD adapter. One would plug it into the microSD connector and then put the regular SD car into the connector at the other end of the (short) ribbon cable. So...yeah. It is possible to use a full sized SD card with a B+ or A+. It's just a little weird.
B.Goode
Thu Dec 18, 2014 5:45 pm
No need to be 'unparliamentary' about it: the enquirer knows that -
I think the distinction being worried about is that between 'SD' and 'SDHC'. I think I am right in saying that SD only supports cards up to 2Gb, and that SDHC is needed for 4Gb up to some larger value
So to @shingster: YES, microSDHC cards of 4Gb and greater do work on the RPi B+.
drgeoff
Thu Dec 18, 2014 10:17 pm
B.Goode wrote:I think I am right in saying that SD only supports cards up to 2Gb, and that SDHC is needed for 4Gb up to some larger value.
Not 100% correct. Prior to SDHC there were a few manufacturers that produced 4Gbyte SD cards. I think they were an unofficial "extension" of the SD spec.
I know they exist because I have one which works fine in an old Dell X50v PDA (WM2003SE) and gives the full nominal 4 Gbyte. SDHC cards do not work in it.
I've never seen another one and I haven't seen them advertised since a long time ago.
FTrevorGowen
Fri Dec 19, 2014 9:19 am
Interesting ... confirms my suspicions ;) AIUI (from the suppliers I used at the time) SDHC card readers/writers were introduced into camera's first, with the intention of "rolling out" to computers in ~12 months or so later. Hence my two first 4Gb SDHC cards were supplied with USB-stick style card readers/writers (integral brand). Not so sure about the microSDHC (physical) format though. I think it's "predecessor" was "transflash" (which may have been equivalent to SD) but I don't recall seeing microSD cards only microSDHC (but, then again, I didn't have any need for such and thus wasn't really "loooking" :) ).
Trev.
drgeoff
Fri Dec 19, 2014 4:39 pm
Re Transflash and micro-SD. From http://en.wikipedia.org/wiki/Secure_Digital:
"At CTIA Wireless 2005, the SDA announced the small microSD form factor (and SDHC, with capacities in excess of 2 GB and a minimum sustained read and write speed of 17.6 Mbit/s). SanDisk had conceived microSD when its CTO and the CTO of Motorola concluded that current memory cards were too large for mobile phones. The card was originally called T-Flash, but just before product launch, T-Mobile sent a cease-and-desist order to SanDisk claiming that T-Mobile owned the trademark on T-(anything)[citation needed], and the name was changed to TransFlash. TransFlash (sometimes abbreviated TF) and microSD cards are the same; each can be used in devices made for the other."
shingster
Tue Dec 30, 2014 1:14 pm
So back on topic
I have now purchased a Kingston class 4 micro SDHC card and a Adata class 10 micro SDHC card for my project
Do i need to do anything to them more besides downloading and installing Kali linux on to them?
Before i insert it into the Pi and boot it
klricks
Tue Dec 30, 2014 2:36 pm
shingster wrote:So back on topic
The image is installed to the SD card using Win32diskimager which is a bit for bit copy so nothing needs to be done to the SD card.
Questions about Kali Linux can probably be better answered over on the Kali forums.....
shingster
Tue Dec 30, 2014 7:28 pm
i see thanks
drgeoff
Tue Dec 30, 2014 7:48 pm
Please do not ask the same question in more than one thread.
