hi,
im planning to run a model a+ with a small 12" touch screen (via hdmi) to display a webpage on "frameless" chrome.
ive found that LXDE only blanks the screen after 10 mins but I really wanted it to put the monitor in to standby to save power and the back light after 10 mins.
does anyone know how I would go about this please?
thanks
Re: lxde :- screen to turn off after 10 mins not blank
so found out that the raspbery pi cannot switch off a monitor correctly using dpms...
is this a old problem? the monitor im using turns off ok on a windows pc
thanks
thanks
Search the forum for cec-client, You have to compile a version yourself (the repository version doesn't work for me). And you have to create your own script that runs in the background and turns the monitor into standby mode.
Minimal Kiosk Browser (kweb)
oh poo... nothings ever simple
- DougieLawson
- Location: A small cave in deepest darkest Basingstoke, UK
- Contact: Website Twitter
cec-client is relatively easy.vectraboyv6 wrote:oh poo... nothings ever simple
But before you head down that track what happens if you simply use tvservice -o to disable the HDMI signal. Use tvservice -s to get status and tvservice -p to switch it back on in preferred mode.
Then install cec-client and try these
echo "on 0" | cec-client -s
echo "standby 0" | cec-client -s
echo "pow 0" | cec-client -s |grep "power status:"
hi
the tvservice commands work brillantly so i install the cec stuff and its a no go, just sprouts aload of garbage out.
going to try and create a script, maybe python? to read the mouse movements and bash out the appropiate tvserve commands
(or borrow someone elses if all ready done
thanks
thanks
