henadin
Unable to parse package file...
Wed Dec 17, 2014 7:55 am
Hello! I've never had any breaking errors like this on my raspberry pi.
I've just installed Raspian wheezy on my Pi.
I SSH into my Pi then I ran sudo raspi-config and expanded filesystem, changed password, then rebooted.
When the pi loaded back again I logged in, then proceeded to try to install a program.
Here's what we get:
"sudo apt-get install apache2
Reading package lists...Error!
E: Unable to parser package file /var/lib/dpkg/status (1)
E: The package lists or status file could not be parsed or opened.
What can be causing this issue?
dr.meow
Re: Unable to parse package file...
Fri Mar 06, 2015 5:44 pm
me too
dr.meow
Sun Mar 08, 2015 8:17 pm
i did find a solution. think it was the second post of this:
http://ubuntuforums.org/showthread.php?t=1841228
basically - remove cached package lists with:
sudo rm -rf /var/lib/apt/lists/*
then download new package location lists with:
sudo apt-get update
irishcanuck
Wed Oct 21, 2015 11:09 am
I was getting the same error trying to update a fresh install of jessie; I had ignored the error from unzip when uncompressing the image onto a vfat filesystem. The problem was that vfat is only capable of 4gb files or less and had truncated the 4.3 gb raspbian image to 4gb. Hence I encountered the above error when attempting to apt-get update
M.Amin
Tue Aug 07, 2018 6:15 am
Hi!
this problem has a simple solution. don't worry :)
just execute this in command line (terminal):
sudo mv /var/lib/apt/extended_states /var/lib/apt/extended_states_tmp
