skoky
WebLogic 12 on Raspberry
Sat Dec 13, 2014 8:18 pm
Hello
I made WebLogic 12.1.3 to run on Raspberry PI! It works great. Weblogic now supports Java8 and this is possible. Two changes needs to be done:
a, it must run with -client as servers JVM is not supported from Oracle
b, to consume less memory -DserverType=wlx should be used. It consumes about 200MB of space
Raspi is great!
Skoky.
venkateshs111
Re: WebLogic 12 on Raspberry
Sun Dec 21, 2014 3:22 pm
Hi Stock,
Thank you for the post.
Could you please provide the exact startup command and the path please.
venkateshs111
Sun Dec 21, 2014 11:23 pm
[quote="skoky"]Hello Skoky,
Hope you are doing good..Just eager to know the startup command. thank you.
Venkat
PikWay
Thu Jan 08, 2015 1:26 pm
Startup command is startWebLogic.sh :)
And startup parameters mentioned by Stock needs to be changed in setDomainEnv.sh
BR,
Pik
Return to “Java”
