i am looking for a correct Resize-Script. The Built-In Tool is not so smart. Because whenn i buy a new SD-Card it could be that the Image from behavior do not fit on it. So the Script should take a little bit Reserve at the end of the current SD-Card or use an internal table for resizing to make sure that it doesn´t matter which Tricks use the manufacturer for size indication.
