Is there a method of self-upgrading the Linux kernel on a Raspberry Pi which is safe against power outages and filesystem corruption.
When running a Raspberry Pi remotely, it's important to be able to upgrade both the filesystem and kernel in a reliable way. Usually, this is achieved by having two partitions or copies of the kernel and a bootloader capable of switching back to a recovery image.
But, as I understand it, the Raspberry Pi bootloader is proprietary code running on the GPU which doesn't support this.
(Also, it seems that the u-boot port does not support USB mass storage, so would have to modify the SD card, which is potentially dangerous?).
Thanks.
Crossposted from http://raspberrypi.stackexchange.com/qu ... nux-kernel
