schelli04
Gertbot - USB to Serial converter
Fri Dec 12, 2014 6:06 am
Hello everyone,
is it possible to connect the Gertbot with a Windows PC using a USB-to-Serial-converter. Or is the Voltage (5V) to much for the uart interface on the gertbot?
I don't want to damage the gertbot.
Thx for answering my question.
DirkS
Re: Gertbot - USB to Serial converter
Fri Dec 12, 2014 10:22 am
Yes, you can as long as you get the right cable.
For example https://www.modmypi.com/raspberry-pi-ac ... spberry-Pi
See also gertbot manual, chapter 2.7
Gr.
Dirk.
Gert van Loo
Fri Dec 12, 2014 3:06 pm
A USB-to-Serial-converter is exactly what I am using in the demo (http://youtu.be/qnr7AlwMDPc)
There are several different types, 5V signals and 3v3 signals. You need to buy the 3V3 version.
Both types output 5V on the (red) supply wire.
I even have run two Gertbots from one USB cable although according to the manufacturer it could only supply enough current for one.
