I am planning on making a gas and pressure sensor for use in my lab.
So I got the following:
- Raspberry Pi B+
- Lots of jumper wires
- A breadboard
- Figaro TGS2600-B00 Gas Sensor: http://uk.rs-online.com/web/p/gas-detection/5389960/
- MCP3008 microchip http://www.adafruit.com/product/856
- MPXA6400A pressure sensor (20-400 kPa range): http://cache.freescale.com/files/sensor ... H6400A.pdf
So I got the microchip and gas sensor working with the 3.3 dcV supply and some Java programming, picture: http://imgur.com/DWI5N8W
I haven't been able to find a pressure sensor that was compatible with 3.3V, so I found one with 5 dcV supply requirement. The MCP3008 works fine with 5.0V supply. But I guess GPIO/MISO isn't so happy about that. Also I'm not sure if any voltage will jump into the RasPi through MOSI?
I'm planning on using a simple voltage divider: http://www.raltron.com/cust/tools/voltage_divider.asp
But I'm not sure where to put it. I guess it must be before GPIO/MISO?
The pressure sensor is very small, so I need to do some careful soldering to fit them into a stripped jumper. Any tips on the way before my clumsy fingers makes a ravage?
