krrishymct
Loading zImage or Image for Raspberry Pi
Mon Dec 08, 2014 2:51 pm
Friends,
I compiled Linux 3.10.9 with RT patch using make bcm2835_defconfig and obtained a zImage and Image files. Now I have a doubt that how to load the zImage/Image into the sd card and boot from it.
Awaiting for your reply. Thanks in advance.
Krrish.
ShiftPlusOne
Re: Loading zImage or Image for Raspberry Pi
Mon Dec 08, 2014 3:24 pm
place it as kernel.img on the fat32 partition. If you're using NOOBS, you need to figure out which is the correct partition yourself.
krrishymct
Tue Dec 09, 2014 1:08 pm
ShiftPlusOne wrote:place it as kernel.img on the fat32 partition. If you're using NOOBS, you need to figure out which is the correct partition yourself.
If i have to configure the memory card from scratch for that kernel what would be the sreps which i should folliw.
ShiftPlusOne
Tue Dec 09, 2014 1:26 pm
I'm not sure what you mean by that. Which steps did you follow to get the card to the stage it's in now? Did you use win32diskimager, dd, NOOBS, something else...?
krrishymct
Tue Dec 09, 2014 1:57 pm
Win32diskimager
ShiftPlusOne
Tue Dec 09, 2014 1:59 pm
Excellent, then just replace kernel.img with the kernel you've compiled.
Return to “Other”
