logie
Why two Raspbians?
Mon Dec 08, 2014 10:17 am
I am absolutely beginning. I have a dozen options in OS to choose from. The first TWO are versions of Raspbian, the first looks like it's on a plug, the second looks as if it's on a card. Is that right? - the symbols are very small!
Re: Why two Raspbians?
Mon Dec 08, 2014 12:40 pm
logie wrote:I am absolutely beginning. I have a dozen options in OS to choose from. The first TWO are versions of Raspbian, the first looks like it's on a plug, the second looks as if it's on a card. Is that right? - the symbols are very small!
The RPi has no BIOS, therefore the boot files and OS are on a SD Card
http://www.raspberrypi.org/help/quick-start-guide
The RPF website has the information http://www.raspberrypi.org/help
RPi 4B 4GB (SSD Boot)..
Mon Dec 08, 2014 12:46 pm
Do you mean on the NOOBS installer screen?
If it has a card icon it means it's available for offline installation. If it has a little plug it means you NEED a wired ethernet connection between your RPi and your home router/switch (online installation) to install that option.
MaxK1
Mon Dec 08, 2014 2:50 pm
I think the OP is referring to the SD card (used in the model A or B or B rev 2) vs Micro SD as used in the A+ or B+.
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
Mon Dec 08, 2014 2:52 pm
MaxK1 wrote:I think the OP is referring to the SD card (used in the model A or B or B rev 2) vs Micro SD as used in the A+ or B+.
Not sure about that - Dougie seems to be on the right track.
FTrevorGowen
Mon Dec 08, 2014 3:06 pm
If the O.P. is using NOOBS then that does offer two "versions" of Raspbian, the second being one setup to boot directly into Scratch**. I wonder if this is the source of confusion?
Trev.
** As can be seen in these, now somewhat old (NOOBS 1.3.2), monitor photographs:
http://www.cpmspectrepi.webspace.virgin ... n_progress
and also (just) for NOOBS 1.3.9 here:
http://www.cpmspectrepi.webspace.virgin ... e_Video.29
logie
Tue Dec 09, 2014 12:38 pm
I think Douglas is right. I clicked on the card version, and it seems to have worked. Many thanks for all replies.
