navtz
Load wifi settings from USB flash drive
Wed Dec 03, 2014 3:34 pm
During start up, how can I make the Wifi adapter get the IP address, subnet mask, gateway IP etc from a USB flash drive? Right now, I'm modifying the /etc/network/interfaces file whenever I want to change them & rebooting. But I need to be able to modify the IP settings from an external USB flash drive.
cdo
Re: Load wifi settings from USB flash drive
Wed Dec 03, 2014 4:01 pm
You can put an interfaces file somewhere on the usb drive and write a small script which mounts it on startup and copies the file to /etc/network.
renatoargh
Tue Dec 27, 2016 12:33 am
Hey! I have just followed your suggestion and came up with this script (enhancements needed)
sudo mount /dev/sda1 /media/usb -o uid=pi,gid=pi
if [ -f /media/usb/interfaces ]
then
  if cmp --silent /media/usb/interfaces /etc/network/interfaces
  then
    echo " "
  else
    sudo cp /media/usb/interfaces /etc/network/interfaces
    sudo service networking reload
    sudo reboot
  fi
fi
Save the code above as `wifi.sh` and add an entry to crontab with `contab -e` like this: `@reboot sh /home/pi/wifi.sh`. You might need to give it execute permissions with `sudo chmod +x /home/pi/wifi.sh`
Hope this helps
HawaiianPi
Tue Dec 27, 2016 5:48 am
Nice, except all of that is unnecessary now. You can put the wpa_supplicant.conf file in the SD card's /boot partition (the only partition visible to Windows/Mac) and it will be moved to the correct location and used when you boot the Pi. The wpa_supplicant.conf file should contain the following:
update_config=1
country=US
network={
	ssid="your-network-service-set-identifier"
	psk="your-network-WPA/WPA2-security-passphrase"
	key_mgmt=WPA-PSK
Edit country=, ssid= and psk= with your info.
www.raspberrypi.org/blog/another-update-raspbian/ wrote:• If a wpa_supplicant.conf file is placed into the /boot/ directory, this will be moved to the /etc/wpa_supplicant/ directory the next time the system is booted, overwriting the network settings; this allows a Wifi configuration to be preloaded onto a card from a Windows or other machine that can only see the boot partition.
Return to “Beginners”
