BMS Doug
Re: Pi Supply Gert VGA 666 shipping.
Wed Dec 24, 2014 1:23 am
I've been trying all night (well since 9pm) to get this working, without any joy.
A+ with usb hub with wifi, keyboard and mouse.
OS is the latest (09/09/14) raspbian, freshly loaded to sd
(Several fresh sd cards waiting to go.)
DirkS wrote: 1. if necessary install rpi-update:
sudo apt-get update
sudo apt-get install rpi-update
done.
2. update to current firmware / kernel:
sudo rpi-update
No need to reboot yet.
done.
Rebooted successfully at this stage on 2nd sd card.
3. Download configuration file for the board:
wget https://github.com/fenlogic/vga666/blob/master/setup/dt-blob-dpi.bin
sudo mv dt-blob-dpi.bin /boot/dt-blob.bin
done
4. Add settings for the board to /boot/config.txt
sudo nano /boot/config.txt
and add the following lines
enable_dpi_lcd=1
display_default_lcd=1
This will enable the board and make it the default display
done
5. It is necessary to blacklist spi and i2c, otherwise the vga666 will not function correctly.
sudo nano /etc/modprobe.d/vga666-blacklist.conf
and add these lines
blacklist spi-bcm2708
blacklist i2c-bcm2708
done
6 Now reboot; if everything is ok then it should come up with VGA resolution (640x480)
blank screen except for "no pc input"
7 Now adjust the resolution for your monitor (see http://www.raspberrypi.org/documentatio ... fig-txt.md)
For the vga board use 'dpi_' instead of 'hdmi_'
For example, adding these lines to /boot/config.txt
dpi_group=2
dpi_mode=35
Would be the equivalent of hdmi_group 2 (DMT), mode 35 (1280 x 1024 @ 60Hz)
And it works nicely with my old Acer AL1711 monitor :)
can't access these.
HTH
Dirk.
Doug.
DirkS
Wed Dec 24, 2014 8:38 am
BMS Doug wrote:I've been trying all night (well since 9pm) to get this working, without any joy.
Went through the whole procedure on an A+ and also ran into problems.
I just noticed that the dt-blob.bin on my B+ is different from the one on my A+... investigating.
Gr.
Dirk
DirkS
Wed Dec 24, 2014 8:46 am
Mea culpa...
I pasted the wrong link to the dt-blob file.
Step 3 should be
wget https://raw.githubusercontent.com/fenlogic/vga666/master/setup/dt-blob-dpi.bin
HTH
Dirk.
Wed Dec 24, 2014 8:52 am
Is it a full DTB blob or an overlay?
In /boot/config.txt add
device_tree=bcm2708-rpi-b.dtb
device_tree_overlay=overlays/bcm2708-rpi-b-overlay.dtb
and you can override the default names for the blobs.
BMS Doug
Wed Dec 24, 2014 10:29 am
Mea culpa...
Step 3 should be
HTH
Dirk.
Yup, that got it, now I have the message
Unsupported signal, adjust your PC output
So I just have to tweak some settings.
Edit: Tweaking did work btw, My (fairly old) TV only supports 1360x768 as a VGA input so when I set:
dpi_group=2
dpi_mode=39
It worked.
Doug.
Guru7
Sun Dec 20, 2015 1:20 pm
can i use my raspberry pi 2 model. it has 40 pin GPIO
Sun Dec 20, 2015 3:44 pm
Guru7 wrote:can i use my raspberry pi 2 model. it has 40 pin GPIO
Yes.
