I'm a newbie and I was trying to do a NOOBS setup on a brand new16GB SanDisk Ultra microSDHC UHS-1 Card by following the instructions on:
http://www.raspberrypi.org/help/noobs-setup/
I downloaded and extracted the ‘NOOBS (offline and network install).
I inserted the SD card in the SD card reader of my laptop where I formatted the SD card using SD Formatter 4.0.
I copied the extracted files/folders to the SD Card.
I safely ejected the SD card from my laptop.
I setup my Raspberry Pi Model B+ - plugging in the monitor, mouse and keyboard cables.
I inserted the SD card into the Pi and then plugged in the USB power cable but nothing happened.
I unplugged the power and checked if I had inserted the SD card properly only to find that the SD card had gotten very hot.
I had another SD card that already had the operating system installed so I put that into my Pi instead to check if the Pi was okay and it booted perfectly.
I also have a Raspberry Pi Model B so I put the SD card into that and the same thing happened - i.e. nothing but the card got extremely hot! Again when I replace the card with another pre-imaged card there wasn't a problem.
I then tried to put the original card back in the SD card reader on my laptop where I could get a smell of burn and there was some smoke!!!
My question is - did I do something wrong which caused this or is it possible that the card is just faulty?
Thanks in advance for any help offered
