mattanl
Raspberry doesn't start automatically after power outage
Wed Nov 26, 2014 3:35 pm
I'm having a strange issue: After power outage, the raspberry pi doesn't start automatically. It means that I see some LEDs but it doesn't start. If I detach and re-attach the power cord from the raspi, it starts.
It looks like a protection mechanism or similar (to avoid frequent start-stops). Are you aware of it? Is there a way to disable it?
Thanks.
DirkS
Re: Raspberry doesn't start automatically after power outage
Wed Nov 26, 2014 3:55 pm
Not aware of any such mechanism on the Pi.
Are you sure it's not starting or is there just no output on a connected screen?
Gr.
Dirk.
drgeoff
Wed Nov 26, 2014 4:25 pm
Is the power outage just a quick blip or sustained for some tens of seconds? If the outage is short there will be some power stored in the PSU that will slowly die away and cause the voltage received by the RPi to fade. This can cause the RPi to enter a mode where it isn't "off" but does does not work properly (eg it appears to freeze or "hang"). When full power is restored the RPi doesn't leave that state.
dom
Wed Nov 26, 2014 5:56 pm
DirkS wrote: Are you sure it's not starting or is there just no output on a connected screen?
That would be my guess. If TV is also powered off and takes longer to boot than Pi it may not be asserting hotplug, so Pi defaults to composite.
That can be forced if we can confirm that is the issue.
adamreisnz
Mon Feb 24, 2020 9:26 pm
I suspect that this was what we experienced with our Pi last week. Is there anything that can be done to prevent this state of non-existence?
The site is quite remote, so going up there to pull the power plug and restore it again is not really an option.
Sounds like the Pi might be better off not running off a backup battery, and just suffer the immediate power cut, which will then at least cause it to reboot when power is restored.
