emgi wrote:The pins you need for FastEthernet (100Mb) are: 1,2 & 3,6.
Nop. For raspberry on pcb side it its 1,3 & 4,6 as you can see on last pictures. Pin 2 connected with 5 and looks like it is CMT transformer pin.
DougieLawson wrote:What the heck are those stupid heatsinks for? You're not running this in the Gobi desert are you?
Past time that pi was used on over 1.2 load with tranciever in small enclosure, so it becomes too hot and laggy (on turbo) even with fan. Heatsinks helped me and temp fall from 90°C to 35°C.
For new project heatsinks useless, but i think no sense to unmount it, because they glued with thermal conductive glue.
Or You are asking about heatsinks on rtl tuner?
