PiGraham
RasPiTab Tablet
Fri Nov 21, 2014 9:43 pm
On kickstarter.
A chunky, slow, low-res and expensive RasPi based tablet. But it is hackable and linux
http://gadgetshow.channel5.com/news/fir ... ickstarter
https://www.kickstarter.com/projects/20 ... -pi-inside
riklaunim
Re: RasPiTab Tablet
Fri Nov 21, 2014 11:08 pm
More expensive than Jolla tablet which got funded in 2h https://www.indiegogo.com/projects/joll ... /x/4177444
And that Jolla is using the same components as Windows 8 x86_64 quad core Intel Atom tablets. At least some do support Linux, although Windows 8 or Android are much better suited for a touch screen display (vs classical Linux desktop window managers).
timrowledge
Re: RasPiTab Tablet
Sat Nov 22, 2014 2:54 am
riklaunim wrote:More expensive than Jolla tablet which got funded in 2h https://www.indiegogo.com/projects/joll ... /x/4177444.
But that's an intel powered tablet. Which is about as interesting to me (YMMV, of course) as a plate of cold jellied eels and lutefisk.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
PiGraham
Re: RasPiTab Tablet
Sat Nov 22, 2014 8:34 am
Do you have a thing against Intel as a company or are you doing something that an Atom cpu isn't suited to, but Arm6 is?
PiGraham
Re: RasPiTab Tablet
Sat Nov 22, 2014 8:38 am
The special feature of RasPiTab is the internal expansion space. The kickstarter mentions add ons that you might expect to be part of a tablet anyway, but someone may come up with some exiting add on.
Still, given the thickness many add ons to standard tablets could fit in a custom back. Eg FLIR ONE thermal camera.
alexeames
Re: RasPiTab Tablet
Sat Nov 22, 2014 10:24 am
Interesting project. But who is the target market?
People who want a hackable tablet? I wonder how many of them there are?
It's got off to rather a slow start.
Alex Eames RasPi.TV, RasP.iO
PiGraham
Re: RasPiTab Tablet
Sat Nov 22, 2014 11:48 am
I think the market for it will be very small. I can't think of a good use for it so far.
It reminds of LittleBox, a RasPi based desktop PC.
riklaunim
Re: RasPiTab Tablet
Sat Nov 22, 2014 1:01 pm
It can run Windows 8 and all of its apps. It supports OpenGL and can behave like a normal PC. But if you want ARM then there are even cheaper ARM Android tablets (but can't do Linux). And even those to some extent may use Arduino or other microcontroller boards via USB-OTG or Bluetooth-Serial.
It's cool to have a hardware project, but it's even better if it's targeted for a wide range of consumers and has sane features/$ ratio.
pluggy
Re: RasPiTab Tablet
Sat Nov 22, 2014 3:32 pm
Good luck to them, but its outside my interest.
I must not tread on too many sacred cows......
gordon77
Re: RasPiTab Tablet
Sat Nov 22, 2014 3:50 pm
Is it simply a Pi (actually the Pi module) with the Pi camera and a lcd display in a tablet shaped box?
PiGraham
Re: RasPiTab Tablet
Sun Nov 23, 2014 3:57 pm
gordon77 wrote:Is it simply a Pi (actually the Pi module) with the Pi camera and a lcd display in a tablet shaped box?
Plus a CM module interface board and battery, yes.
So unlike a normal tablet it has internal GPIO and some expansion space inside the case, which is easy to open up. It also has two full-size USB host sockets on the bottom edge.
