monty166
Complete novice to Pi!
Sat Nov 15, 2014 3:02 pm
I am considering buying a B+ mainboard. I have an imac desktop. Could I use the mac monitor and wireless apple mouse with the Pi? I don't want to buy a separate mouse and keyboard if there is no need. Any help much appreciated.
B.Goode
Re: Complete novice to Pi!
Sat Nov 15, 2014 4:43 pm
monty166 wrote:I am considering buying a B+ mainboard. I have an imac desktop. Could I use the mac monitor and wireless apple mouse with the Pi? I don't want to buy a separate mouse and keyboard if there is no need. Any help much appreciated.
You can't 'simply' plug the keyboard and mouse into the RPi and have the display magically appear on the Mac monitor.
If the monitor for the Mac is a separate unit with a standard HDMI input it can probably be connected to the RPi instead.
Similarly if the keyboard and mouse have standard usb connections you can probably re-use them with the RPi.
What you CAN do quite simply is connect both the RPi and the Mac to a shared local area network and remotely access the RPi from an application window on the Mac. In that case you don't need to disturb the existing connections to the Mac.
http://www.raspberrypi.org/documentatio ... /README.md
