so_la_la
2 OS for beginners
Sat Nov 15, 2014 12:20 pm
i have purchased a rpi b+ along with the hifiberry addon.
I am completely new to rpi and to linux.
My idea now is to set up Pi Musicbox possibly with another OS to run on my rpi.
Basically the pi musicbox is supposed to play music stored on my NAS to my amplifier.
However setting up pi musicbox did not work out at all because Pi Musicbox cannot find any files anywhere and gets stuck.
Now I am going back to reinstall using noobs or berryboot especially since I have been thinking about a second OS for video playback through the HDMI output.
So I need some kind of dual install for, say, Rasbian + Pi Musicbox. How can I achieve this using NOOBS?
Any help is greatly appreciated.
kusti8
Re: 2 OS for beginners
Sat Nov 15, 2014 1:22 pm
You could somehow put the compressed OS into the OS file of NOOBS, search around for how to do that. You could also use BerryBoot and convert Pi MusicBox to squashfs.
B.Goode
Sat Nov 15, 2014 2:33 pm
so_la_la wrote:I need some kind of dual install for, say, Rasbian + Pi Musicbox. How can I achieve this using NOOBS?
https://github.com/raspberrypi/noobs/bl ... os-version
so_la_la
Sat Nov 15, 2014 6:29 pm
Thank you very much.
i have tried and succeeded in installing two OS on the SD card using berryboot.
But how do i actually power up the rpi? All it gives me is "pi@raspberrypi". I guess I am supposed to write sth. But what?
ghans
Sat Nov 15, 2014 6:32 pm
Try
startx
You can set this permanently via
sudo raspi-config
ghans
Sat Nov 15, 2014 6:38 pm
From: http://www.raspberrypi.org/help/quick-start-guide/
"Logging into your Raspberry Pi
After you have successfully logged in, you will see the command line prompt pi@raspberrypi~$
To load the graphical user interface, type startx and press Enter on your keyboard."
so_la_la
Sat Nov 15, 2014 7:32 pm
ok, thanks guys...
so_la_la
Sat Nov 15, 2014 9:57 pm
Alright, I managed to install two Os on the PI one of which (Openelec) is working, the other one (Raspbian?) I don't know.
I desperately try to create some squashfs.-file from the Musicbox img. i managed to extract. However I need a linux machine for it as is described http://www.howtogeek.com/141325/how-to- ... berryboot/ and as kusti8 has pointed out.
To get this linux machine I
a. tried and installed a virtual machine plus ubuntu 14.04 but I cant execute the commands in the console because it requires a password which I have NOT set during the installation process (and it is NOT Adminuser or anything else I found on the web).
b. tried and used the rpi itself but it won't recognise the command sudo, whatever this is, as in "sudo apt-get install squashfs-tools".
This is quite a painful process...
so_la_la
Sat Nov 15, 2014 10:33 pm
yeah the other os is raspbian. In it i can actually install the squashfs-tools but I could not execute the kpartx command which is needed for altering the .img-file.
When installing the squashfs-tools in raspbian it complained about some missing localisation stuff and before, I had been unable to set the locales as required as I didn't know how to tick boxes in the blue screen.
Another question: how do I actually switch off the rpi? I've had Raspbian power down now but the red light on the rpi is still on. I do not know how to restart the rpi other than plugging out and in again the power supply something which I have done today at least 20 times.
kusti8
Sat Nov 15, 2014 10:36 pm
To turn off the raspberry pi, type in:
sudo halt
in LXTerminal, or it is set to boot to desktop there should be a small red button at the bottom right corner.
As for the musicbox.img that is squashfs, I'm trying to make one.
so_la_la
Sat Nov 15, 2014 10:37 pm
oh this would be most welcome!
mahjongg
Sat Nov 15, 2014 10:38 pm
sudo is short for "superuser do" and is used as a command line prefix.
it is used wherever a command must be executed that needs "super user" rights to run. A super user is the systems administrator.
Its an elementary command for debian based versions of linux (raspbian is one of them), and its simply impossible it isn't recognized in a normally installed raspbian.
Its also Linux 101.
so_la_la
Sun Nov 16, 2014 12:08 am
mahjongg wrote: its simply impossible it isn't recognized in a normally installed raspbian.
I thought the problem was rpi didn't recognise the kpartx command.
kusti8
Sun Nov 16, 2014 1:09 am
so_la_la
Sun Nov 16, 2014 2:57 am
kusti8 wrote:Made the file
Super, thank you so much!
I managed to install it and berryboot now gives me a start menu with three osses i can select from.
However, MusicBox does not work properly i.e.:
the start up routine issues a warning: "mount point /squashfs does not exist. Skipping mount…"
the web interface on me notebook does not seem to recognise musicbox at all, it warns of not being able to find the settings.ini file and would not connect to any hard drives.Image
All it says is "trying to reach musicbox. please wait"
Inspecting the SD-card revealed that there are hardly 60mb of 16gb recognised and no raspbian, openelec or musicbox file can be detected.
Oh and how do I shutdown after I have logged out of musicbox? No matter what I type after "musicbox login" it will always just ask for a password.
Anyway all these questions do not directly pertain to the original subject...
Sun Nov 16, 2014 6:09 am
If you are using a version of Windows to read the SD Card then it will only see the FAT32 Boot Partition, Windows does not natively support Linux EXT partitions.
http://sourceforge.net/projects/ext2fsd
RPi 4B 4GB (SSD Boot)..
mahjongg
Sun Nov 16, 2014 1:16 pm
so i replied that is was impossible that sudo wouldn't work (as in command not recognized) in a normal (not corrupted) raspbian.
for raspbian a user with password is installed per default:
user = pi
password = raspberry
its in the quick start guide.
so_la_la
Sun Nov 16, 2014 1:54 pm
Ok, you were right mahjongg, my fault!
I managed to have a look into the contents of the extfs-formatted sd-card but not through ext4tc but through http://www.paragon-software.com/de/home ... index.html.
Anyway, I could not locate any file called settings.ini where musicbox is supposed to save its settings. I have searched through all folders to my best knowledge.
kusti8
Sun Nov 16, 2014 2:06 pm
I looked around in the github page and looks like it is in the boot partition of the file (I could be wrong). You could possibly copy the settings.ini from here and then manually put it into the image and see if that works.
https://github.com/woutervanwijk/Pi-Mus ... ttings.ini
so_la_la
Mon Nov 17, 2014 9:07 pm
Thank you but i couldn't sort out how to boot Musicbox with Berryboot successfully. However, I could do so using another sdcard. BUT it turned out that obviously Musicbox is having troubles supporting the Hifiberry DAC I have, so, for the time being, I am moving away from Musicbox in favour of RuneAudio, which claims to support the Hifiberry out of the box.
Another thing I am interested in: can I update my current installation of OpenELEC (4.03 or so, it came with berryboot) by this particular http://www.hifiberry.com/files/images/o ... igured.zip version?
I am aware of how to connect OpenELEC to my Windows PC Explorer but I cannot extract the four files mentioned here http://www.raspberrypi.org/forums/viewt ... 66#p546566 from the .img-file.
All in all I am not really impressed with the playback abilities of the OSses and even less so with the Apps. For Windows Phone, Chimney seems to be sth decent, but I haven't gotten round to trying it out just yet.
Mikelele
Wed Apr 29, 2015 12:41 pm
Hello Everybody,
I have purchased a my first ever raspberry pi!!! I bought the RPi2 and I am also trying to get installed in my raspberry pi two OS, Openelec (Mediacentre) and Pi Musicbox (basically for my Spotify account).
I have the berryboot up and running with openelec, but I am struggling to get Pi Musicbox, I have created the Squashfs image and I am able to install it on the Berryboot.
When I launch Pi Musicbox, all looks good but the settings.ini If I place this file in the image, Openelec and Pi Musicbox stop working...
Does anyone have Pi Musicbox working with Berryboot?
Thank you very much in advance for your help,
Mikelele
kusti8
Thu Apr 30, 2015 10:28 pm
Try putting it in NOOBS instead. I couldn't get it to work. The settings.ini file was not found and it probably requires a lot of work which lazy me just doesn't want to do. There are instructions on how to do this on the NOOBS github page in the advanced section.
